Where to get a diff installed?
- Thank you received: 330
25 Mar 2023 21:35 #248232
by Gadget
Where to get a diff installed? was created by Gadget
Toying with the idea of buying a Quaife ATB for the rear of my Jimny, but I've no idea where to get it installed once I buy it.
Any recommendations for garages/workshops who know what they're doing with Jimnys? Closer to the South East the better, but I'm willing to travel to get the job done right.
Thanks.
Thanks.
- Thank you received: 2005
26 Mar 2023 06:06 #248233
Replied by Lambert on topic Where to get a diff installed?
Don't know any specific ones down south but when I get that far with Tem I'm probably going to talk to a gearbox rebuilding place like RS transmissions in Bradford which is probably a bit far for you.
The following user(s) said Thank You: Gadget
26 Mar 2023 09:06 #248236
Replied by Soeley on topic Where to get a diff installed?
What about
Buzz Special Vehicles
They have done quite a few Jimny builds as well as Jeeps.
I bought my OME lift kit from them, but they are a bitt too far for me to visit.
26 Mar 2023 12:25 #248238
by sniper
Replied by sniper on topic Where to get a diff installed?
Any reputable gearbox repair shop should be able to do it for you.
I took the chance to do all the half shaft bearings and seals whilst it was apart, only added an hour and its a fully refurbed axle....
sniper
sniper
- Roger Fairclough
- Thank you received: 225
26 Mar 2023 17:05 #248248
by Roger Fairclough
Replied by Roger Fairclough on topic Where to get a diff installed?
You don't need a Jimny specialist. Rear beam axles are still a common commodity, most pickup trucks use them, so a look on Google for your area will supply enough for your needs.
On the other hand, removing a diff. unit is not difficult and does not require an above average tool kit although you will require a torque wrench, spring gauge and dial gauge and magnetic stand to re-assemble it. If you want to give it a go, there are people on this forum who can assist.
Roger
Roger
- Jonesie
26 Mar 2023 18:22 #248249
by Jonesie
Replied by Jonesie on topic Where to get a diff installed?
Had defender stuff done by these people as has my mate had done on his ranger.
www.hardyengineering.co.uk/
