Towing 7pin socket
06 Mar 2023 19:22 #247935 by Rackster
Towing 7pin socket was created by Rackster
Hi all I got a 55 plate Jim it came with tow bar and electrics fitted put my trailer on indicators ok brake lights ok no normal lights checked the socket it was pretty manky so changed it  lights still no good checked with multi meter only 2.5 volts on the lights don't know what to do or check thanks
06 Mar 2023 22:41 #247938 by DrRobin
Replied by DrRobin on topic Towing 7pin socket
Trace the wiring back to see where it is spliced in to. It is usually connected in to wiring behind the panel in the back on the near side. Very often ‘Scotch’ blocks are used that are quick but can give a poor connection.
You might need to remove the bumper to trace the wiring, but it comes off really easily.
Robin
16 Mar 2023 14:36 #248063 by Rackster
Replied by Rackster on topic Towing 7pin socket
Traced the wires to the joints bared the wire before the joint still no good All the wires end up in a black box on the left hand side still scratching my head
16 Mar 2023 15:10 #248064 by facade
Replied by facade on topic Towing 7pin socket
It will save you time and effort if you just buy a new trailer socket wiring kit and fit it, removing the black box and existing wires.
Possibly the black box is one of those 7 way relay doings that isolate the trailer electrics from the car, and also monitor the indicator load so it beeps when the trailer is indicating. These need an extra 12V power feed as they have relays that switch the lamps from it to avoid any load on the car's lighting circuits. It could be faulty, or a poor connection somewhere.
Or it could just be a monitor/beeper, or it could be a junction box.
17 Mar 2023 06:21 - 17 Mar 2023 06:27 #248068 by yakuza
Replied by yakuza on topic Towing 7pin socket
I bought a new cable kit for my Jimny as it came with no trailer connecations or hitch. First one I got was for the models with the rear lights down in the bumper but mine got those up at the wing corners so had to get another. (This is probably different in different markets )
My kit just got the extra blinker relay. works great. All easy plug and pray hooked up in the rear inner panel and came with everything.
I chose the newer/better 13 pin socket. I help maintain the Red Cross cars for SAR and we changed all the towing sockets from 7 pin to 13 pin and we have so much less hassle now. Lot less work to maintain the 13 pin as the connectors are much better quality. Allways some poor connection on the 7 pin.
Last edit: 17 Mar 2023 06:27 by yakuza.
17 Mar 2023 12:32 #248071 by facade
13pin are better, but they are tested at MOT, and have to work, although if you fit a 13 to 7 pin adaptor for the MOT, the tester won't remove it and 7 pun sockets are not tested for function, only appearance.
Time to create page: 0.099 seconds
