Gen 4 MOT
  • Jonesie
01 Mar 2023 20:38 #247827 by Jonesie
Gen 4 MOT was created by Jonesie
Evening all,
Bearing in mind Gen 4’s are now readily in MOT range has anyone had any issues when going for their first MOT?
Reason I ask is I have removed my rear seats and put a front runner floor in.
The rear belts are still attached albeit 50% hidden under a LCV gen floor mat.
Someone mentioned if the belts are fitted the they have to be useable…..
So do I remove the belts completely?
01 Mar 2023 21:40 #247829 by Roger Fairclough
Replied by Roger Fairclough on topic Gen 4 MOT
My Gen.4 past it's MoT 2 weeks ago. I had removed the back seats and the seat belts way back but I checked with the tester beforehand and he advised me that there wouldn't be a problem. You can check with your proposed tester as too whether or not no seats but seat belts still fitted poses a problem or just remove the belts. You will need a 2 ohm resister per belt to tell the computer the belts are still there.
Roger
01 Mar 2023 22:37 #247831 by Gadget
Replied by Gadget on topic Gen 4 MOT
Had my second MOT in January, no issues. I have one belt clipped out of the way and it wasn't mentioned.
02 Mar 2023 11:19 - 02 Mar 2023 11:25 #247841 by Busta
Replied by Busta on topic Gen 4 MOT
If there are no rear seats fitted then the seat belts aren't tested. The tester will issue an advisory that no rear seat were fitted at the time of the test.
Last edit: 02 Mar 2023 11:25 by Busta.
Time to create page: 0.087 seconds
