wheel spacers
27 Feb 2023 13:22 #247781 by madman
wheel spacers was created by madman
Hi Everyone,
I have just fitted 15x8 ET0 steel modular wheels and 215/7515 tyres from 4x4 tyres to my 2022 Jimny, before tightening the nuts I spun the wheel and it knocked the balance weights off, on trying to hand tighten the wheels nuts I noticed the inside of the rim was hitting the steering arm on both N/s and O/S. I have spaced the wheels out with washers just to see what is required and I had to take it out 7.5mm minimum,  Does anyone know of a good quality spacer they could recommend in the smallest size possible. 4x4tyres.com only supply a 30mm spacers which would take me way beyond the arches.
Many thanks
Ken,
Man of many machines small and large , 2001 Kap Jimny and 2023 LCV 2" lift and very happy.
27 Feb 2023 14:07 #247782 by DrRobin
Replied by DrRobin on topic wheel spacers
I understood that the stndard wheel size is 15" 5.5" with ET5, if you have gone to 8" wide and ET0 I think you are going to need 30mm spacers to space the wheel correctly, see this calculator
www.1010tires.com/Tools/Wheel-Offset-Calculator#
You might be able to get away with less, but not sure what else will hit when on full lock.
Can I ask why you went to 8" wide, I have 215/75 r15 fitted to standard 5.5" alloys?
Robin
27 Feb 2023 15:46 #247783 by madman
Replied by madman on topic wheel spacers
Cheers Robin
The two options on the 4x4tyres.com site were 7" and 8" guess I would have been better with the 7" .
Thanks for your help.
Cheers Ken.
27 Feb 2023 15:49 #247784 by Roger Fairclough
Replied by Roger Fairclough on topic wheel spacers
The recommended rim size for a 215/75R15 tyre is 6" with variation between 5.5" - 6.5". Your 8" rim is way bigger than you need and require and this is your problem. I fitted 215/75R15 tyres to Suzuki 5.5" steel rims with no problems. If you fit any spacers to solve your problem, you will probably fall foul of the law relating to tyre tread being outside of the bodywork and you will promote early wear and tear on wheel bearings and king pin bearing. In my opinion you will be better off to change to standard Suzuki rims.
Roger
27 Feb 2023 16:12 #247785 by madman
Thanks Roger.
27 Feb 2023 19:13 #247786 by DrRobin
I don’t suppose you can send them back can you?
8” wide wheels are too wide for your tyre profile, you might have sealing or side wall problems.
There are several retailers who sell aftermarket 5.5 inch steel wheels, including Jimnybits and Raptor.
The following user(s) said Thank You: madman
Time to create page: 0.091 seconds
