Snapping sound
- Greakking972
21 Feb 2023 20:49 #247706
by Greakking972
Snapping sound was created by Greakking972
I’m facing an issue with my jimny I got stuck in the mud yesterday i engaged the 4wheel low to come out of the mud after removing the 4wd I keep hearing a snapping sound when I move off in 1st gear and also when I clutch in to switch frm 1st to 2nd gear
- Thank you received: 2004
22 Feb 2023 04:26 #247708
Replied by Lambert on topic Snapping sound
First things first get under the car and give everything a good hard wiggle with your hands and see if anything is moving more than it should for instance do the propshafts have any vertical or horizontal movement, does the transfer box move up or down. Then lift the wheels one at a time and feel for movement top to bottom and side to side and when rotating listen for odd noises.
- Greakking972
22 Feb 2023 14:55 #247712
by Greakking972
Replied by Greakking972 on topic Snapping sound
I will double check everything and will get back to you
- Greakking972
24 Feb 2023 03:21 #247727
by Greakking972
I didn’t find anything wrong now the jeep has a heavy vibration when it’s idling and and sometimes I hear a similar sound when I start the vehicle
24 Feb 2023 04:43 #247728
If there's nothing obvious and it's getting worse then I would suggest booking it in with your local specialist for a thorough exam as it could be a fairly serious issue.
24 Feb 2023 10:43 - 24 Feb 2023 10:45 #247732
by facade
Replied by facade on topic Snapping sound
Have a look at the crankshaft front pulley, they have a nasty habit of delaminating, and vibrate under load, then after a while when you rev it up the whole outside comes off.
Last edit: 24 Feb 2023 10:45 by facade.
Time to create page: 0.095 seconds
