Re:On board storage options?
- Thank you received: 1999
09 Feb 2023 10:07 #247461
On board storage options? was created by Lambert
Whatcha. I need help. Again.
currently I have my EDC bag that I lift in and out every day full of useful farmer things. It works well. However I also have many things like boxes of emergency nails and screws and stuff and also the wheel change equipment wedged all over but out of the way of the main load area. Thing is all of it could easily be 30 kg which is essentially dead weight most of the time but it's always there. I'm trying to decide if I would be better with all of it in a crate in the load area that is easy to remove but takes up real estate or do I carry on and forfeit the weight saving available?
09 Feb 2023 12:53 #247469
Replied by jackonlyjack on topic On board storage options?
I'm just collecting parts
Going to put some cable tray across the rear load space
connected where the grab handles fit above rear windows
Just for my straps/strops,first aid kit,spare belts ect
09 Feb 2023 18:18 #247480
Replied by Lambert on topic On board storage options?
I've tried roof storage and it's not for me, with 4 bales of hay in the back I need the head room. Really it's more about having the weight easily removable as opposed to the lack of volume when the weight isn't a priority. I guess it would be prudent to take everything out and get an accurate weight of it all and decide with that in mind.
- Roger Fairclough
- Thank you received: 225
09 Feb 2023 22:42 #247495
by Roger Fairclough
Replied by Roger Fairclough on topic On board storage options?
I removed the back seats and fitted a home made box for basic walking essentials and maps. The top of the box is flat so could easily accommodate another box. The sides of the main box have tie down points for straps.
Roger
Roger
10 Feb 2023 09:18 #247498
by LM42
Replied by LM42 on topic Re:On board storage options?
5 door jimny?
Sent from my 2201116SG using Tapatalk
10 Feb 2023 09:23 #247500
Replied by Lambert on topic Re:On board storage options?
Initial reports suggest they are even worse for payload than the 3 door.
Time to create page: 0.729 seconds
