Bonnet Latch
  • JINXED2007
3 years 11 months ago #246367 by JINXED2007
Bonnet Latch was created by JINXED2007
I opened my bonnet this morning to fill the washer bottle up, when i closed the bonnet it is snagging on the first inital latch but not closing completely. Any ideas before I take to garage,  Suzuki Jimny 2003
TIA
3 years 11 months ago #246369 by DrRobin
Replied by DrRobin on topic Bonnet Latch
Is it just clogged with muck or ice or lack of grease?
Do you normally close it by dropping it from a few inches or do you close it slowly and then the final close by pushing with your hands?
3 years 11 months ago #246372 by Mike G
Replied by Mike G on topic Bonnet Latch
I had that issue a short while ago.  I just loosened off the catch, adjusted it up a bit and then retightened them.  That fixed it for me.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
3 years 11 months ago #246376 by Lambert
Replied by Lambert on topic Bonnet Latch
It's also possible that the little screw in rubber bungs at either side of the bonnet need a little adjustment.
3 years 11 months ago #246384 by fordem
Replied by fordem on topic Bonnet Latch
TIA
There are two different mechanisms in play here - that first "initial latch" is a separate spring loaded safety catch that is there to stop the bonnet from flying up and blocking your view if the cable operated latch somehow releases (or is released) - from what you describe the cable operated latch is not holding, try pushing the release handle under the dash back, it may be binding, it could also be a lack of lube as has been suggested.
Time to create page: 0.107 seconds
