Engine Heating up
- Jamesl
3 years 11 months ago #246099
by Jamesl
Engine Heating up was created by Jamesl
Hi peps,
I have been having overheating problems in my 2011 Jimny for sometime now. I have had to already replaced the radiator, water pump, the thermostat, the radiator cap and engine! But the problem persists!!
Basically, the temperature slowly creeps up when the car is stationary after it has been driving. With the previous engine, I ran into this problem on two road trips. When I slowed down in towns the engine would overheat. But it would also creep up to red after about 2 hours of driving. We had to pull over to allow it to cool. Suffice to say, the engine was eventually destroyed.
After the new engine (which was a few months ago), it has happened three times: once after going 90km/hr for about 15mins, another time after going 100km/hr for about 1 hour, and the latest after going 60km/hr for about 10mins. I have managed to keep the car from overheating by putting on the heater which results in the engine temperature stabilising.
I am baffled by it. I was wondering if anyone has heard anything similar or had suggestions as to the cause.
Cheers guys
Cheers guys
3 years 11 months ago - 3 years 11 months ago #246101
by Scimike
Replied by Scimike on topic Engine Heating up
Viscose fan coupling not working?
When I first start my car the AC fan will rotate quickly, but soon after stops or reduces to a slow rotation. This initial rotation is due to my main cooling fan viscose coupling still being engaged from the engine being run the day before (hot engine). It's air through the radiator driven by the cooling fan, hence the AC fan rotates in this air. The stop soon after is it responding to the fact the engine is cold, cooling fan disengaged again until the engine warms up.
The AC fan, which is not on by the way, is a tell tail of your viscose coupling operation and so main cooling fan operation. Just a simple one to check first.
Last edit: 3 years 11 months ago by Scimike.
- Jamesl
3 years 11 months ago #246107
by Jamesl
Replied by Jamesl on topic Engine Heating up
Thanks man for your reply. So I am trying to understand it. My Jimny seems to have a viscose fan and an electric fan in front of the radiator. The electric is the AC fan? And the viscose fan is the general cooling fan? They both seem to be turning fine when I turn the vehicle on.
I did always suspect that the air flow was a contributing factor but didn’t understand how. I think it was always going but maybe not as fast as it should have been?
- Jamesl
3 years 11 months ago #246108
by Jamesl
I have just tried sticking a cardboard roll in the fan at operating temperature and I was able to stop it without any damage to the roll. So should I say the viscose fan is broken?
- Thank you received: 2004
3 years 11 months ago #246110
Replied by Lambert on topic Engine Heating up
Yes. It's possible to split the unit and replace the oil using silicone oil found in RC car dampers 6000 is about right. Or buy a new one.
The following user(s) said Thank You: Jamesl
3 years 11 months ago #246116
by Scimike
Can't say for sure about cardboard roll, I've got a fear of shoving things into rotating plastic. It doesn't sound right, although viscose is never truly 100% coupled. It should have put up a bit of a fight as you stopped it. Worth checking further or get a used / new one as Lambert indicates.
just for clarity you are correct. AC fan is electric and is in front of Radiator. Viscose coupled cooling fan is belt driven on the engine side. From a cold start (after hot) both should turn, but after about 30 seconds the AC fan will stop rotating. That's how a cold start appears to me and a working system.
