Re:automatic tranmission capacity
- danielbz
23 Nov 2022 16:47 #246067
by danielbz
automatic tranmission capacity was created by danielbz
hello
somebody knows why in the jimny manual page 8--9 (407 from the pdf) it says that jimny atf oil tranmission capacity is 5.7 L?
Automatic transmission oil “SUZUKI ATF 3317” 5.7 L (10.0 Imp pt)
my jimny is automatic and it only takes 2 liters, is there somewhere else you gotta flush?
Regards
Regards
23 Nov 2022 17:51 #246069
Replied by mlines on topic Re:automatic tranmission capacity
Under normal circumstances you cannot completely drain the automatic.
You can only change around 2 litres. This is why I recommend "keep it fresh" IE change regularly as a lot is old fluid
Sent from my moto g42 using Tapatalk
23 Nov 2022 18:24 #246070
by Delux
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
Replied by Delux on topic Re:automatic tranmission capacity
Its one of those 'If it works, dont @*&$ about with it' jobs!
Back when I was a humble mechanic at a Mitsubishi deallership we had to replace 2 Evo X SST gearboxes because people had changed the oil when they didnt need to. 1st one was destroyed because the customer didnt fill it correctly and drove it without enough oil in it. The 2nd one filled it with the wrong oil. When it mixed with the residual oil in the valve block it made some sort of brown ATF jelly!
Later, as a Suzuki tech, I attended Suzukis UK headquarters for their Automatic transmission course. The lecturer explained many of the items we get to mess about with in the workshop were units replaced and returned under warranty. In his time as the motor vehicle lecturer only 2 had ever been returned so we didnt have enough auto gearboxes to go round!
Suzuki automatic gearboxes are pretty reliable. Unless the oil is burned brown, almost black or resembles strawberry milkshake leave it alone!
Many auto specialists will cycle the oil rather than just fill it up. (Mackie transmissions in Glasgow and Landrover in Aberdeen anyway!) They have a powerful pump connected to big drums of the correct fluid, they connect it to the cooler pipes and it circulates the oil removing all the air/contamination.
- danielbz
24 Nov 2022 01:37 #246076
by danielbz
Replied by danielbz on topic Re:automatic tranmission capacity
are there atf cooling lines in the new jimny 1.5 ivory?
regards
regards
- Thank you received: 2004
24 Nov 2022 10:14 #246078
Replied by Lambert on topic Re:automatic tranmission capacity
The gen3 has a transmission cooler built-in as part of the main radiator, I doubt that the 4 is much different.
24 Nov 2022 11:30 #246080
by saxj
Replied by saxj on topic Re:automatic tranmission capacity
The Gen 4 auto is the sameThe gen3 has a transmission cooler built-in as part of the main radiator, I doubt that the 4 is much different.
