No o2 sensor on M13A
- fitzcollins
31 Oct 2022 23:41 #245681
by fitzcollins
No o2 sensor on M13A was created by fitzcollins
Hi all, I recently purchased a 2004 jimny. On doing an examination, I noticed that there was no o2 sensor. Judging by the tyre pressure instructions on the door post that was in french I figure that it must have been built by the Santana factory in Spain. - is there any connection?
fitzcollins
fitzcollins
- Thank you received: 2004
01 Nov 2022 06:00 #245683
Replied by Lambert on topic No o2 sensor on M13A
As in its missing the O2 sensor or its never had one?
- fitzcollins
02 Nov 2022 22:09 #245716
by fitzcollins
Replied by fitzcollins on topic No o2 sensor on M13A
Seems it never had one, there is a bolt in the hole where it goes.
03 Nov 2022 00:25 - 03 Nov 2022 00:39 #245717
by fordem
Replied by fordem on topic No o2 sensor on M13A
I like to play the devil's advocate - how do you get "seems it never had one" from "there is a bolt in the whole where it goes"? Couldn't a previous owner have unbolted the O2 sensor and fitted a bolt in it's place?
I could understand the statement "seems it never had one" being made if the manifold had no bung to take one.
In the interests of full disclosure I should mention that I have owned more than one fuel injected Suzuki that did not have an O2 sensor, and those manifolds did not have the threaded bung to accept one. On the one that I still have, (a 98 GV with a J20a engine) the wiring harness connector, pre-wired for the O2 sensor is present, but, there is no bung on the manifold.
Try looking behind the glove box - do you see anything like this ...
Those are two different views of the CO2 adjusting resistor fitted to my car, if your Jimny didn't have an O2 sensor from the factory, it should havea CO2 adjusting resistor.
Last edit: 03 Nov 2022 00:39 by fordem. Reason: additional information.
Time to create page: 0.096 seconds
