Jimmy Newby
31 Oct 2022 08:48 #245667 by DrRobin
Replied by DrRobin on topic Jimmy Newby
The other thing to look at is the Octane rating of the fuel you are using. 95 or 97 RON is standard here, but your fuel might be lower (92 RON) perhaps?
As already mentioned the difference between a US and Imperial gallon is quite a bit. Finally tyre tread pattern, road surface and average cruise speed will all make a big difference.
People quoting 36mpg will be Imperial gallons, smooth road surface, road or [mild] A/T tyres and 50-60 mph cruise speed.
There was a post on here from a member who gets 160 miles from a tank, he runs big tyres, a lift, has a bigger engine and goes off road, but 160 miles works out at less than 20mpg Imperial.
31 Oct 2022 17:33 #245673 by fitzcollins
Replied by fitzcollins on topic Jimmy Newby
Thanks for your input Lambert.
31 Oct 2022 17:35 #245674 by fitzcollins
I have been sooo tempted to go back stock but there is a huge cost attached.
31 Oct 2022 17:39 #245675 by fitzcollins
It gets worse, - where I am in the Caribbean we only get 87 or 90 octaine and US gal quantities, couple that with 235x75x15 tyres and a 3" lift. - I am screwed.
31 Oct 2022 17:46 #245676 by fitzcollins
Not sure if I am doing this the right way. - my other question is, is it possible to cut an 1" off the springs? - with 3" lift springs and the big tyres I am up 6" on the already high Jimny. - the height makes it feel very unstable.
Cheers
31 Oct 2022 18:59 #245677 by jackonlyjack
Replied by jackonlyjack on topic Jimmy Newby
Yes you can chop a coil off........BUT your tyres will possibly rub
If you lower it by 1" i would say also reduce tyre size down to 215 75 15
Are you still on standard gearing this will not help mpg with 29" tyres
My jimny has 3" suspension 1" body lift and 32" tyres 1.6L engine
gear reduction 150 ish miles to a tank
Time to create page: 0.214 seconds
