Fitting a rear spoiler..
- HardtopSoftop
4 years 3 weeks ago #245594
by HardtopSoftop
1st's 1st and 2nds nowhere...
Fitting a rear spoiler.. was created by HardtopSoftop
I've just acquired a rear spoiler for my Jimny.
Has anyone had success fixing it on with an adhesive,or is it best to drill and bolt?Thanks.
- Thank you received: 679
4 years 3 weeks ago #245595
Replied by DrRobin on topic Fitting a rear spoiler..
I haven't fitted a spoiler on my Jimny, it doesn't go fast enough for one, so not sure of the best method, however, there is a wiki article here:
www.bigjimny.com/mediawiki/index.php/Rea...spoiler_installation
Robin
Robin
4 years 3 weeks ago #245596
by 300bhpton
Replied by 300bhpton on topic Fitting a rear spoiler..
What sort of age vehicle is it?
Drilling may well cause potential rust generation locations and/or water ingress. Plus the need to remove trim. But would provide the most solid fitment.
I believe the 4th Gen JimnyStyle vehicle (the one on their site) only uses 3M tape to hold the spoiler in place.
No need to drill and easy fitment. Although I guess given enough time it may not hold as well, but I really wouldn't like to say. It might have the potential to damage the paint, but shouldn't if it was well polished before sticking in place.
I guess worse case would be if it did fall off, you may not know until some time later on.
4 years 3 weeks ago - 4 years 3 weeks ago #245598
by Scimike
Replied by Scimike on topic Fitting a rear spoiler..
If you are going to glue it on try this stuff
www.toolstation.com/puraflex-40-pu-sealant-adhesive/p85566
Its the poor man's Tiger Seal (it's the same stuff without the ££££)
Also available in white.
The good:
It sticks like nothing on earth once set, so don't get it wrong.
The bad
It can take up to 24hour to cure and it gets everywhere, so masking tape and gloves required. But once set it's a bugger to get off.
It is very good. Always have some in my freezer for trim panels and glazing / sealing on my automation projects.
That said I have never seen a Jimny spoiler and so am not sure how they are supposed to fix.
The good:
The bad
Last edit: 4 years 3 weeks ago by Scimike.
The following user(s) said Thank You: HardtopSoftop
- HardtopSoftop
4 years 3 weeks ago #245621
by HardtopSoftop
Replied by HardtopSoftop on topic Fitting a rear spoiler..
Thanks for the replies...As said,Jimnys don't need a spoiler, so it is purely a personal thing to fit one...Someone l know mentioned Tigerseal so I'll probably go down the adhesive route..
THanks again...
THanks again...
Time to create page: 0.082 seconds
