Key fob not working
  • Dee92
  • Visitor
  • Visitor
22 Oct 2022 19:37 #245532 by Dee92
Key fob not working was created by Dee92
Hi, new to this forum!
I bought a 62 plate Jimny earlier this week, love it already!
However, when I went for the test drive, the garage advised that the fob had just stopped working so they replaced the battery for me but it still wouldn't work. I can only use the key manually now to access the car.
I did read a thread on here about cleaning the buttons and circuit with contact cleaner. I gave that a go earlier using cotton buds. There was a bit of "mist" inside the key and general gunk/dirt which I have cleaned. However, the fob still doesn't work :(
Thinking about getting another battery just in case it's a dud.
Does anyone have any more tips or tricks?
22 Oct 2022 22:32 #245534 by Pete
Replied by Pete on topic Key fob not working
Hi,
I put a new battery in and had to ‘pair’ it again. I made some notes… not sure if this was the order that got it working in the end.
Key in ignition (driver door open)
Turn on till 2nd (lights)
Press lock and unlock
Close door
Hope that helps.
Pete
Rocky | 2004 Gen3 M13a
The following user(s) said Thank You: Dee92
  • Dee92
  • Visitor
  • Visitor
23 Oct 2022 07:31 #245535 by Dee92
Replied by Dee92 on topic Key fob not working
Thanks Pete! I will give that a go today, fingers crossed
23 Oct 2022 08:13 #245536 by DrRobin
Replied by DrRobin on topic Key fob not working
My key fob started getting very poor, so thought it was the battery, although when I took the battery out and measured it on a multimeter it was fine.
I also noticed quite a bit of muck in there, cleaned it with electrical contact cleaner and it was good as new, so muck build up must be a common problem.
Let’s hope the re-program works.
There is a page in the wiki about reprogramming
www.bigjimny.com/mediawiki/index.php/Key...g_transmitter,_alarm
Robin
23 Oct 2022 13:53 - 23 Oct 2022 13:53 #245540 by Scimike
Replied by Scimike on topic Key fob not working
If reprogramming does not work try cleaning the buttons again, it's the common problem.
WIth the battery out drench the buttons with contact cleaner and work them on / off until the cleaner has evaporated. Then do it again but leave it all to dry for 30 minutes before you fit the battery and try again. I doubt you did much with cotton buds, it needs a tougher touch.
Good luck
Last edit: 23 Oct 2022 13:53 by Scimike.
