Winch switch
4 years 1 month ago - 4 years 1 month ago #245453
by 300bhpton
Winch switch was created by 300bhpton
Does anyone know if you can get a switch to use to activate a winch that matches the factory switch panel?
Last edit: 4 years 1 month ago by 300bhpton.
4 years 1 month ago #245460
by Busta
Replied by Busta on topic Winch switch
Suzuki are normally pretty basic with things like this, using industry standard sized parts where they can. Try measuring a switch and using those dimensions to search for similar switches on a components site like RS Online. That's how I found a good match for my older Jimny.
- Thank you received: 679
4 years 1 month ago #245461
Replied by DrRobin on topic Winch switch
I just drilled the blank and fitted a rocker switch with an LED on my Gen3 for an accessory. I had the rocker switch so it didn’t cost anything.
I assume you are using a relay or solenoid on the winch, otherwise the current will be too high for the dash switch.
- Thank you received: 2004
4 years 1 month ago #245464
Replied by Lambert on topic Winch switch
Is this as an isolation switch or a line in, line out, momentary switch? If it's the latter be careful as it's not unheard of for such a switch to cause the line to keep retracting on its own, doing serious damage to people and things.
4 years 1 month ago #245466
by 300bhpton
Replied by 300bhpton on topic Winch switch
Looking for an isolation switch (via a relay). Didn’t really fancy drilling holes in the dash or obvious aftermarket switches. Although I guess drilling a blanking plate and a toggle switch wouldn’t be too bad.
Found a few options on eBay. On looks similar, but I guess buying it is the only real way to see.
4 years 1 month ago #245468
Replied by Soeley on topic Winch switch
Have a look on
HERE
, I believe the switches are the same size as some Toyota switches as well.
The following user(s) said Thank You: 300bhpton
Time to create page: 0.109 seconds
