Replacement engine
  • RachP
27 Sep 2022 15:03 #245157 by RachP
Replacement engine was created by RachP
Hi all,
I have no experience with Jimmy’s (as will become clear).
We recently bought a 2000 JLX Jimny that needs a new engine (G13BB). I’m looking for a reconditioned engine and not had a lot of luck via breakers sites.
I’ve found one from a 2008 model (M13BB).  Can that be fitted into ours?
Or, can anyone point me to a reliable Jimny engine dealer?
Thanks in advance,
Rach
27 Sep 2022 17:52 #245158 by Lambert
Replied by Lambert on topic Replacement engine
Welcome to the forum. The swapping of a g13bb with the m13a is not a simple one. Swapping between a g13 and the g16 out of the Liana is a definite option as they are the same long block just different displacement. The big one though is that all g series engines are getting quite rare now because so many were scrapped because the bodies rusted.
27 Sep 2022 19:01 #245159 by fordem
Replied by fordem on topic Replacement engine
I don't think the Liana was ever fitted with a G-series engine, just the M-series - it might be possible to use a G16 from something like a Grand Vitara or a Baleno
28 Sep 2022 03:18 #245163 by Lambert
Sorry you are right I meant baleno.
28 Sep 2022 11:11 - 28 Sep 2022 11:16 #245170 by yakuza
Replied by yakuza on topic Replacement engine
depending on markets (country) the G-series has been in other suzukis too like Swift. However the ignition and fuel systems are more alike on a baleno engine from the same year model. 99' baleno will fit a G-series jimny, but earlier will not fit as easy as they got a different coil setup.
I think most of the problem with the lack of G-series enginses is that the minute they come into the breakers they get sold due to large demand and slow supply. the G tend to break down in a larger rate than the M-series.
Edit: and as for the M engines that do not break down as much, and have been used in a lesser desirable model like the Liana is easy to get hold of. Just a small ding sends a Liana to the breakers as they cost less used and not so many people bother to fix them. (at least here in Norway)
Same M16 can be found in a swift but then the engine cost twice as much from the breaker as the liana engine.
Last edit: 28 Sep 2022 11:16 by yakuza.
28 Sep 2022 14:17 #245176 by fordem
I don't see this as an M vs G discussion, the thread starter has an early Jimny with a G series engine and is looking for a replacement, the later M series engine is not a simple swap.
Time to create page: 0.098 seconds
