Plastic selection for back door trim.
- Thank you received: 2004
20 Sep 2022 06:12 #245014
Plastic selection for back door trim. was created by Lambert
Fairly self explanatory, what would be a good plastic to use as a replacement door card? The hardboard I have currently is looking tired and is not really robust enough as a couple of tool handles have found their way through it and it is not happy about getting wet. Don't want aluminium as it will be too loud and rattle and need covering. Had thought about abs but I worry that it's a little brittle in thin sections? I also thought about stokbord which is ideal but I don't have any off cuts and a full sheet is mega bucks. What are my options?
20 Sep 2022 08:27 #245015
by LesNewell
Replied by LesNewell on topic Plastic selection for back door trim.
I used textured 3mm ABS sheet for the dash on the trials car. It gets a fairly hard life and so far no damage.
You can get it on eBay for a reasonable price
Another option is PVC foam board but you'd probably need about 6mm thickness. The range of colours is pretty limited as well.
- Thank you received: 679
20 Sep 2022 08:45 #245016
Replied by DrRobin on topic Plastic selection for back door trim.
I used 3mm grey PVC to make my dash board box (then wrapped in black vinyl) and also for the front recovery point covers. If you heat it up it will bend, just keep it in place whilst it cools.
Mind it isn't cheap to buy, especially if you want a big sheet.
An alternative would be [marine] ply, it's waterproof and reasonably durable, you could paint it or wrap in vinyl/carpet.
20 Sep 2022 09:17 #245019
Replied by Lambert on topic Plastic selection for back door trim.
The thinner the better as I'm trying to maximize internal volume. PVC sounds good. Not particularly bothered about colour as long as it's not transparent. Will price some up.
20 Sep 2022 13:24 #245020
by fordem
Replied by fordem on topic Plastic selection for back door trim.
Check the yellow pages for sign manufacturers in your area and then give them a call and ask them about coroplast - it's a corrugated plastic sheet very similar to corrugated cardboard and I have used it successfully to make replacement door cards, essentially replacing the hardboard & reusing the original vinyl.
My local sign manufacturer will sell me what ever size piece I need. He will also sell 3mm PVC sheet which I've used to do fairings for roof racks.
