The 'Ash-Tray' CB
- Thank you received: 667
26 Aug 2022 16:24 - 26 Aug 2022 16:25 #244753
The 'Ash-Tray' CB was created by DrRobin
I decided I would fit a CB, mostly after the BigJimny event and did a bit of listening round here first, there isn't much on and what there is mostly 'toilet' language, but since the CB was only £45 I thought what the heck.
I bought a PNI 6500 CB, it is so small it fits in place of the ash-tray
To hold it place, I made a new ash-tray holder out of aluminium and bolted the CB cradle to it.
I will power it from the Cig socket, but hard wire it round the back as I use the socket for my DashCam.
For the antenna, I wanted it on the back and went for a 'Spring Stinger' colour coded to the Jimny.
I made an antenna bracket from some M8 Stainless threaded rod with a M8 Stainless tube, then drilled the spare wheel holder.
A few Stainless nuts and washers complete the bracket.
The fit is quite snug between the spare wheel and rear wiper blade, but it all goes in.
I have the coax to route, I will drill the rear door, pass it through and next to the door wiring, then through the cab to the dash. I will have to cut the plug off to do it and solder a new one on.
Robin
Robin
Last edit: 26 Aug 2022 16:25 by DrRobin.
- Thank you received: 1999
26 Aug 2022 17:20 #244754
Replied by Lambert on topic The 'Ash-Tray' CB
That's cool, could hide it well out of the way.
26 Aug 2022 20:45 #244755
by Scimike
Replied by Scimike on topic The 'Ash-Tray' CB
That's so neat, nice installation.
Its so good I am tempted to do the same as the ash tray is never used. The tech just looks better even though in my case It's highly likely it's won't get used as well
27 Aug 2022 07:15 #244761
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic The 'Ash-Tray' CB
That's a tidy little use of space. For my install, I managed to feed the RF cable through the same place as the rear door wiring loom. I just cut a slit in the rubber to aid passing through and didn't need to drill anything. Bit of WD40 always helps sliding through. Then once it was through, I just put a bit of electrical tape round the rubber to seal it up again.
29 Aug 2022 21:13 #244779
Replied by yakuza on topic The 'Ash-Tray' CB
Same CB I bought. read some tests on it, should be good value for money. although it seems I am the only one in Norway with a CB :dry:
Have you seen the 8 watt mod? (google it , most likely not allowed in the UK either)
I fit mine below the ashtray.
Not so easy too see the display there, so better to put it higher.
Remember to put an extra ground wire for your door, and to the antenna base. Could be there is weak ground there on the mount.
30 Aug 2022 20:09 - 30 Aug 2022 20:20 #244799
Replied by DrRobin on topic The 'Ash-Tray' CB
Thanks guys.
I have seen the 8w mod and channels mod, but haven’t done either yet, I will see how it goes.
I did check the match using a small analyser (I have a ham license and HF, VHF, UHF radios so accumulated a fair bit of test kit) and it was quite good, also the earth is good, but I did add an earth strap just in case, thanks for the tip.
I wanted the coax hidden so did drill the rear door near to the spare wheel mount. Note the tape over the car plugs. PL-259 plugs don’t seal so fill up with water after a period of time.
Then sealed it up with some rubber tape. The cables came through quite easy.
I then fed the coax next to the door wiring and through the rubber cable duct.
The coax was then passed through the side panel, then under the seat and carpet next to the drive tunnel, under the hand brake cover and along the side of the gear stick cover to the radio.
Routing the coax this way means it is hidden from view so won’t become caught or damaged. It did involve removing a few panels, but these seem to come off I need a fairly regular basis on my Jimny.
Then for a quick test, 40 channels but no one on. Still I have an old portable CB and that proved the PNI was working as well as a small spectrum analyser which showed the antenna was radiating quite nicely. Perhaps I should drive to the coast and see if I can reach Norway?
Robin
Robin
Last edit: 30 Aug 2022 20:20 by DrRobin.
Time to create page: 0.243 seconds
