M13A fuel injector options
09 Aug 2022 14:32 #244463
by Old Neil
M13A fuel injector options was created by Old Neil
what are the options of up grading fuel injectors on a M13A,higher flow rate
09 Aug 2022 18:55 #244466
by Busta
Replied by Busta on topic M13A fuel injector options
Easiest option is to fit injectors from any other M series Suzuki with a bigger engine, like a Swift, Liana of Grand Vitara.
What engine mods have you got?
09 Aug 2022 23:13 #244471
by Old Neil
If you put too high flow rate injectors in for the mods would motor run rich or would the computer back the fuel rate off ?
Sent from my SM-A336E using Tapatalk
Replied by Old Neil on topic Re:M13A fuel injector options
I'm just getting info at the moment, i wanted to put a swift sport engine in but can't find one in AustraliaBusta wrote: Easiest option is to fit injectors from any other M series Suzuki with a bigger engine, like a Swift, Liana of Grand Vitara.
10 Aug 2022 20:43 #244493
by Busta
Replied by Busta on topic Re:M13A fuel injector options
The ECU monitors the fuel mixture via the lambda sensor, and adjusts the injector duration accordingly. So as long as they are small enough for slow running and big enough for full power the injector size doesnt make any difference.
The following user(s) said Thank You: Old Neil
Time to create page: 1.313 seconds
