I'm trying something I shouldn't
4 years 5 months ago #243566
by Vandoni
I'm trying something I shouldn't was created by Vandoni
Hello, I'm a new user of this forum and I've been lurking on here and getting a lot of useful answers from the posts you guys make, I have a gen 3 2000 Jimny 4WD and I've been using it for all the normal stuff like commuting and the occasional off-road trip.
These last few days though, I let my love for speed get to me and instead of only pulling during the straights I started going faster during turns as well (yes i know I shouldn't speed altogether, but I only do it when there's no one around) and I noticed that my RR tyre has started to whine a bit, that made me curious, so I started pushing even more. The result is: I think I'm starting to lightly drift with my little Jimny. Do you guys think it's possible to get a drift going and keep it drifting for some time? Or should I just give up? Also I like this challenge because I don't think a lot of people drift these magnificent cars on asphalt so I'd be one of the few able to do it.
- Thank you received: 2005
4 years 5 months ago #243568
Replied by Lambert on topic I'm trying something I shouldn't
Welcome to the forum. First a Jimny in good condition with fairly sensible and newish tyres should have more grip than it is able to overcome. Secondly because it's narrow and softly sprung and because of the thing with the SJ in America Suzuki deliberately engineered the Jimny to understeer first. Thirdly and this is quite important because of the very short wheel base the controllability of a slide is a very tight window of opportunity before you are into the scenery. I'm not saying a Jimny can't slide, they are good fun in snow or somebody else's field but on tarmac the level of commitment required vs the opportunity to get it very very wrong is too high. Also doing it on the road is recklessly endangering other people and will get you nicked.
This is my last Jimny with lower suspension trying quite hard on a track, certainly more so than any responsible person would on road and it's not sliding.
The following user(s) said Thank You: Vandoni
4 years 5 months ago - 4 years 5 months ago #243569
by Scimike
Replied by Scimike on topic I'm trying something I shouldn't
In standard form the answer is no.
THe Jimny is too underpowered and has too much grip to sustain a drift.
Yes you can get under steer and invoke a rear slide if the conditions are favourable, but you will not sustain "drifting" for any distance.
That's not to say it can't be done though. Damp tracks are your friend to start with and the quick route to interesting handling is to fit some skinny or not so good tyres, your "drifting set". Unfortunately it's trial and error for this but thin rears are a good start. Please note I am not advocating you modify or try on the public roads, but great fun and have a go on a track day like Lambert.
Last edit: 4 years 5 months ago by Scimike.
4 years 5 months ago #243570
by Vandoni
Replied by Vandoni on topic I'm trying something I shouldn't
Oh i understand, that seems right, I had some doubts about the whole thing because of how the car is structured as you said.
I don't live in america and mine is a european jimny (i don't know if this means that it's gonna understeer less) but i noticed that it is actually quite controllable while the rear tyres are screeching, and it started to lose rear traction completely a few time, although the tyres always regained it a second later.
And yes i understand that doing it on the road is dangerous but it's the first time i do this and i always wait for the road to be completely empty before trying something stupid, and i decided to try drifting the car on a dirt track next, since i have one near where i live.
Thanks for the answer!
4 years 5 months ago #243571
by Vandoni
You might be right about the whole power thing, the 1.3 engine really doesn't have a lot of power down low and I stayed in 3rd gear and kept the revs at 3k more or less so there might not have been enough torque to the wheels, though the car did lose traction for a fraction of a second a few times it regained it almost immediately, but the whole time i think the nose of the car was pointing the inside of the turn and not straight ahead like when i normally turn, could that maybe be a resemblance of a 4 wheel drift?
4 years 5 months ago - 4 years 5 months ago #243574
by Scimike
Yes you can get the back end to step out if you are enthusiastic in the turn and push the throttle, but it's only going to be a momentary action until it more than likely grips again.
The engine simply lacks power to offer any form of throttle control in a slide, and the high profile / soft suspension will rock shifting the weight pattern on each wheel, again making control hard. It's a sort of on / off situation offered by the Jimny, spin out or grip.
I Suspect a locker on the rear would help, but it's an expensive modification to find you still don't have enough power. That said it helps with off-road, so two functions for the price of one!
Anyone on here drift with the rear locker on?
Just asking, no experience of them myself.
And in the wet, when the road is quiet , I believe it may go around mini roundabouts particularly well , allegedly
Last edit: 4 years 5 months ago by mlines.
Time to create page: 0.107 seconds
