Red dot yellow dot?
- Thank you received: 2004
20 May 2022 08:33 #243374
Red dot yellow dot? was created by Lambert
Can someone remind me, on tyres the yellow dot is the lightest point of the tyre and should sit on the valve hole. The red dot is the highest point and should correspond to the lowest point of the wheel if indicated. If not it should go to the valve hole and additional balance is necessary? Is that right?
- Bill Portland
- Thank you received: 77
20 May 2022 10:34 #243378
by Bill Portland
Replied by Bill Portland on topic Re:Red dot yellow dot?
I can tell you that the yellow dot is aligned with the valve on all my gen4 tyres
Sent from my Power Armor 13 using Tapatalk
20 May 2022 10:58 #243379
Replied by Lambert on topic Re:Red dot yellow dot?
Thanks. That is what I thought. I'll aim for that when I mount the new tyres.
25 May 2022 08:50 - 25 May 2022 09:08 #243444
by facade
If the rim isn't marked the yellow dot goes to the valve, to save a bit of balancing weight.
I suppose it is harder to roll & glue a steel wheel together true*, whereas it is no trouble to skim the alloy round when they finish it in Japan than it is to make it wobbly like they do over here (there is a dimple in the rim on some alloys)
Rubery Owen used to make all our wheels, including the legendary "Rostyle". They were about as round as a egg.
Replied by facade on topic Red dot yellow dot?
Exactly right, the red dot takes preference if the rim is marked, original Suzuki steel wheels are marked with a blue spot. You want the tyres to run as true to round as possible, you can always stick some more weights on.Can someone remind me, on tyres the yellow dot is the lightest point of the tyre and should sit on the valve hole. The red dot is the highest point and should correspond to the lowest point of the wheel if indicated. If not it should go to the valve hole and additional balance is necessary? Is that right?
Last edit: 25 May 2022 09:08 by facade.
25 May 2022 09:13 #243445
Replied by Lambert on topic Red dot yellow dot?
Upon receiving the tyres it seems that radar have enough confidence in their products being round that they only have a yellow dot. This in the absence of any other information is going against the valve hole. We will see how accurate they are when I get them balanced.
Time to create page: 0.088 seconds
