Jimny 1999 just wont rev up
  • Kirk6866
09 May 2022 06:51 #243272 by Kirk6866
Replied by Kirk6866 on topic Jimny 1999 just wont rev up
I have changed the injectors and the throttle body still no luck
09 May 2022 07:24 #243274 by Scimike
Replied by Scimike on topic Jimny 1999 just wont rev up
Ok, at least you can exclude them.
Not much left and yes its possible a sensor, typically the cam sensor, but others are possible MFA etcl.
Looking at your list sensors appear to be the only items not changed.
OK some other simple suggestions:
Compression test and they are all the same?
Intake tubing / system not blocked.
Anyone have any other suggestions?
09 May 2022 11:59 #243277 by Lambert
Replied by Lambert on topic Jimny 1999 just wont rev up
One thought, is the cam belt timed correctly? Easy enough to take the front cover off the motor and check the timing marks line up correctly.
09 May 2022 12:45 #243281 by DrRobin
Replied by DrRobin on topic Jimny 1999 just wont rev up
What do the plugs look like?
When you drained the tank did you flush the fuel system through? There might be water sitting somewhere which is causing fuel flow.
Always assuming it doesn't have a misfire or timing, another cause of an engine not revving is heavily choked. Have you got an OBD reader or any other way of looking at the fuel trim?
When you take a plug out does it smell of pertrol or does the exhaust smell of unburnt fuel?
  • Kirk6866
11 May 2022 07:11 #243294 by Kirk6866
bottom pully has been loose snapped bolt in front of crank worn keyway timming way out
changing engine
11 May 2022 11:53 #243296 by Lambert
That would do it.
Time to create page: 0.372 seconds
