Jimny 1999 just wont rev up
- Kirk6866
08 May 2022 06:43 #243255
by Kirk6866
Jimny 1999 just wont rev up was created by Kirk6866
I have a 1998 Jimny with a G13bb engine i think not sure?
My issue is that it started to take a long time for the revs to build even with the throttle down to the floor then slow to build revs from idle and there is not enough power to pull away.
Now its starts and runs like a pig on idle and the min you touch the throttal it cuts out?
I've have checked,
new fuel
fuel tank
fuel pump
fuel filter
fuel lines
air filter
plugs, leads and coils
exhaust for blockage
vacum hoses for leaks
throttle position sensor
any help would be great
Thanks
I've have checked,
new fuel
fuel tank
fuel pump
fuel filter
fuel lines
air filter
Thanks
08 May 2022 07:23 #243256
by Scimike
Replied by Scimike on topic Jimny 1999 just wont rev up
Any history behind this issue?
Has it suddenly started and was fine before or has it had past problems and this is the latest?
The fact you changed the tank suggests it's been standing or the fuel storage has been comprised in some way, this makes me think the fuel system is the issue, possibly blocked injectors.
It's just a guess at this stage on my part, if you can add any more details let us know.
- Kirk6866
08 May 2022 07:39 #243257
by Kirk6866
Replied by Kirk6866 on topic Jimny 1999 just wont rev up
I bought the vehicle as an unfinished pick up conversion – I am just completing that body ect
It has a 2 inch body lift and a 3 inch suspension lift and new wheels all from jimny bits and a new cat exhaust
Its been standing since 2014 with the old petrol I fitted a new battery and it fired up and run but slow to pick up because the rear of car has gone getting the tank to look at the pump and filter was easy – I drain all old fuel and replaced the pump works and its getting fuel at the rail
We have then gone through the basics as I mentioned – when it did run the engine was running fine after it picked up off the throttle – but now as mentioned will only idle low and run like a pig
Thanks in advance for any help
08 May 2022 09:08 #243260
by facade
Replied by facade on topic Jimny 1999 just wont rev up
The usual culprit for refusing to rev is a blocked catalyst or exhaust- the manifold catalyst breaks up and the chunks block the one under the floor.
Given the fuel system has been messed with, I'd be checking the fuel pressure, a worn out pump still runs but produces no pressure, or you might have debris in the regulator keeping it open.
08 May 2022 09:16 #243261
by Scimike
Highly likely something in fuel system is the cause, blocked Cats can cause rev issues, but most with this don't report a rough Idle, it just won't rev.
So check the pump pressure^^^^, fuel lines are clean and then each injector is actually injecting something. As I found myself recently, old petrol buggers things up unless you are very lucky.
- Kirk6866
08 May 2022 09:20 #243262
by Kirk6866
the catalyst and exhaust are new and it seems to be good fuel presure at the injector rail?
although i will get that tested.
the fuel pump is fine we have tested that?
we will have a look at the injectors today to see if they are blocked
could it be sensor or somthing like that?
thanks for your help
Time to create page: 0.244 seconds
