Brakes
- GrahamJimny
4 years 7 months ago - 4 years 7 months ago #242473
by GrahamJimny
Brakes was created by GrahamJimny
The brakes on my Jimny 2004 have not been right since I got it. feel soft, or sometimes not there.
The handbrake never worked either.
I’ve bled the front right but couldn’t get the left bleed nut off front wheel.
My friend is round now and he said we should take the back wheels off, as he thinks its all somehow connected.
Is this right, will the adjustments in there - correct the handbrake as well?
Cheers
Cheers
Last edit: 4 years 7 months ago by GrahamJimny.
- GrahamJimny
4 years 7 months ago #242476
by GrahamJimny
Replied by GrahamJimny on topic Brakes
looks like there is a worn bush now behind the back left wheel.
Is that expensive to change?
- Roger Fairclough
- Thank you received: 225
4 years 7 months ago #242477
by Roger Fairclough
Replied by Roger Fairclough on topic Brakes
I assume that the "worn bush" is the wheel bearing? If so then there are a couple of strings concerning rear wheel bearings that will help you. They are within the last few days.
Roger
Roger
- Roger Fairclough
4 years 7 months ago #242478
by Roger Fairclough
To check which brake is causing the softness, you need to isolate each brake hose, front and back and then push down on the brake pedal,. It should feel solid after no more than 10-15mm to take up mechanical slop. At this point I have changed direction and would suggest you do a full brake fluid change and then come back to us. Yes, you will have to slacken off all the bleed nipples, there is no other way to do it.
Roger
Roger
- Thank you received: 2004
4 years 7 months ago #242484
Worn suspension bushes can go one of 2 ways either you have a hydraulic press and they come out easy enough or you don't have a hydraulic press and have to fight them out with sockets and all thread, hacksaws and fire. Often it is cheaper just to get the arm off and ask a local garage to change the bush. Which ever way it's not a particularly novice friendly job.
- GrahamJimny
4 years 7 months ago - 4 years 7 months ago #242495
by GrahamJimny
Cheers Lambert, yes I saw on YouTube a guy pulling them off. Looks like a real headache. I purchase the parts anyway, so may do the brakes myself and see what bolts are like around the suspension arm, and may take to garage to press out.
But I've got an MOT coming up so Im very anxious myself. Theres a lot of cosmetic damage to the exterior shell, like cracks in bumper and sharp edges around wheel arches. Im hoping they will let that stuff go.
Last edit: 4 years 7 months ago by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
Time to create page: 0.086 seconds
