Rear storage
22 Feb 2022 11:10 #241973 by Conev
Rear storage was created by Conev
Hello guys lately i was thinking of removing my jimny 2002 rear seats for more storage. i removed the base seats but the back ones when i unscrew the bolts the bolts keep turning and not unscrewing what can i do ?
Also any ideas for cheap mods for back storage .All i want is a flat surface to put my dogs cage in and some other tools or staff ..
2002 Manual M13A jimny RHD
2" Black Raptor Lift kit
Ironman 4x4 steering Damper
8" steel wheels 215/75/15 AT100
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
22 Feb 2022 12:24 #241974 by gv42
Replied by gv42 on topic Rear storage
I got the base deck by FrontRunner a good base kit
22 Feb 2022 12:50 #241975 by Lambert
Replied by Lambert on topic Rear storage
If the bolts are just spinning it's one of two things either the captives on the back have separated or the threads are striped. Either way it's going to be time for very careful use of the Dremel tool to cut the heads off. Not a particular good time I'm afraid.
22 Feb 2022 16:17 #241980 by DrRobin
Replied by DrRobin on topic Rear storage
I made a box to sit in the rear for this exact purpose, I wanted a flat back so our dog doesn't roll around and fall in to the boot.  I also wanted a tool box that was hidden.  It was made out of plywood and pine slats from an old bed.  Finally it is covered with black carpet.
Hope it gives you some ideas if you are retaining the seats.
Robin
Boot box with seats up
With the seats down
Lids open showing the tool trays (Velcro holds the lids up)
Tool trays removed allows access to original boot
22 Feb 2022 16:28 - 22 Feb 2022 16:32 #241981 by Scimike
Replied by Scimike on topic Rear storage
This is what I did to mine - got rid of the rear seats totally. It's a plywood sheet covered in carpet with a hinged section to the rear that still allows access to the jack / rotten floor area . Its bolted down using the seat belt bolts with tie down points included as well, so it can be removed easily if needed.
May not offer enough space, it depends what you want to carry.
Last edit: 22 Feb 2022 16:32 by Scimike.
Time to create page: 0.143 seconds
