Engine sound
13 Feb 2022 20:34 #241842 by Conev
Engine sound was created by Conev
Does anyone know what this weird sound is coming from and how to fix it ? It seems to be more quiet when ac is on but not completely quiet.. It started today when i was on a mountain road trip ..M13a engine manual 2002
2002 Manual M13A jimny RHD
2" Black Raptor Lift kit
Ironman 4x4 steering Damper
8" steel wheels 215/75/15 AT100
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
13 Feb 2022 20:39 #241843 by Conev
Replied by Conev on topic Engine sound
It comes from the front of the engine near the outside belts of the ac
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
    FullSizeRe....MOV.mp3
14 Feb 2022 09:58 #241845 by Scimike
Replied by Scimike on topic Engine sound
Good grief, that’s a good (in a bad way) sound!
No idea as to the source, but a mechanics stethoscope or screw drive placed (carefully) around the engine is a very good way to locate the source.
Alternatively disconnect the AC and Alternator belts and have a feel of any rotating parts. Start and see if noise has gone, if it has it’s going to be something driven by the belts, ie  alternator, water pump / cooling fan / AC unit  / idler bearing
14 Feb 2022 10:14 #241846 by Lambert
Replied by Lambert on topic Engine sound
Agreed that is not as happy noise.if it's less with the air-conditioning off it's kinda suggesting that magnetic drive clutch on the AC is dying but it's like said above, you need to eliminate everything in turn.
14 Feb 2022 15:52 #241848 by Conev
I just found that is the ac compressor and its rattling when rotating.. do i have to change all the ac compressor unit or just the rotator thing for the belt ?
Tema 4x4 Snorkel
Wing
Window deflectors
Rear seats removed
14 Feb 2022 18:31 - 14 Feb 2022 18:33 #241853 by Scimike
The AC pulley (rotor?) is made up of two parts,  The outer on which the belt runs and a second part connected to the compressor shaft. Between the two is an electric clutch that connects the two.
AC off then only the outer is rotating with the belt.
AC on then the outer and inner are coupled together, hence the AC shaft turns.
So it you rotate with the AC off, checking that the inner part / shaft is not turning, does it still rattle?
If yes then it sounds like the problem is the electric clutch, aka the pulley. You can take it apart to check for rust or damage. I've seen a few pictures on here of someone doing this, but can't find at the moment.
Last edit: 14 Feb 2022 18:33 by Scimike.
Time to create page: 0.095 seconds
