Gear grinding
- Maxthemelon
20 Jan 2022 15:19 #241317
by Maxthemelon
Gear grinding was created by Maxthemelon
Hi all!
So I've noticed that my car has been making some gear grinding sounds while driving along but it doesn't seem to be in the usual way . I've got a 2021 model, manual, and as Im driving along (every time after I start the car for a drive and within 200m) I get the sound of gears grinding and then after a short time it sounds like a gear clicks into place and I feel it clunck. This happens every time.
It doesn't seem to correlate with a specific gear that I'm in, speed that I'm going or whether the clutch is pressed or not. While it is making that noise I can move up or down through the gears without any issues and pressing the clutch doesn't seem to help. It feels like, while it's making the sound, the gear I'm in is still engaged and I'm able to drive normally and then something just clunk's into place. This all seems to be happening along side what feels like driving normally. No slipping of gears, no high revs, it's feels fine at the time (bar the clunck)
Anyone had any experience with this? I'm not car savvy but I think this is a pretty good explanation of what is happening.
Cheers
Cheers
20 Jan 2022 18:42 #241322
Replied by yakuza on topic Gear grinding
If you try to engage and disengage the 4x4 before you start driving, and find that the sound does not appear if you do so before starting your trip, it might be something with the front axle vacuum hubs not completely releasing or with the transfer case.
A teacher I had at school 40 years ago complained his car made nasty sounds from the wheels. Found that some of his students had put pebbles in the hub caps of his beetle.
- Roger Fairclough
- Thank you received: 225
20 Jan 2022 20:51 #241329
by Roger Fairclough
Replied by Roger Fairclough on topic Gear grinding
A 2021 model should be under warranty so I suggest you take it back to the dealer.
Roger
Roger
- Dirtbird
20 Jan 2022 23:39 #241335
by Dirtbird
Replied by Dirtbird on topic Gear grinding
Lads, I think Yakuza is right the clunk could be the 4x4 and vacuum system.
- Thank you received: 2004
21 Jan 2022 05:06 #241338
Replied by Lambert on topic Gear grinding
This is a warranty claim. It shouldn't be making any of the noises you described.
- Maxthemelon
21 Jan 2022 11:28 #241352
by Maxthemelon
Replied by Maxthemelon on topic Gear grinding
Thanks, that sounds like a good idea. I'll try this before my next drive and see what happens!
Time to create page: 0.107 seconds
