Rough idle when warm
  • Nickfortey
18 Jan 2022 21:21 #241291 by Nickfortey
Rough idle when warm was created by Nickfortey
Hi Folks,
G13BB starts ok when cold and ticks over ok but sounds a bit lumpy, when warm doesn’t want to start then cuts out, drives fine when warm or cold. I have replaced coil packs and HT leads and cleaned throttle body and IAC valve. Today it threw up a code for the first time P 0400, which I believe is EGR valve.
so tomorrow I plan getting it off and cleaning it and checking the resistance….is it just two bolts holding it on? Anyone had theirs off?
Nick
18 Jan 2022 22:08 #241292 by DrRobin
Replied by DrRobin on topic Rough idle when warm
P0400 is the EGR valve, perhaps it is sticking? If that doesn’t fix it check the vacuum lines for leaks.
Time to create page: 0.092 seconds
