Wind causing a rattling sound - Gen3?
  • DrRobin
  • Platinum Member
  • Platinum Member
  • Newbie in Northumberland
23 Dec 2021 14:55 - 23 Dec 2021 14:56 #240757 by DrRobin
Driving home last night in my 2011 Gen 3, doing about 60mph with a slight head wind and rain I could here what sounded like a hollow rattle from the front of the car, but it only happened when the speed was above 60mph and/or there was a head wind.  I de-clutched and free wheeled, the sound eventually stopped as the speed dropped.
In a sheltered area (no wind or a slight tail wind) there was no hollow rattle sound all the way up to 70mph, so I think it is wind/rain getting in somewhere.  Has anyone experienced this and might know where to look?  Or should I just turn up the stereo and put up with it.
Last edit: 23 Dec 2021 14:56 by DrRobin.
23 Dec 2021 15:40 - 23 Dec 2021 15:46 #240758 by Scimike
Ok just one idea from the many rattles I have found and fixed.
The aerial. If it slips down very slightly from the fully extended position you can get a hollow rattle that's wind / speed dependant. Its the aerial rattling in its tube. Well that's what mine did.
The fix - pull it all the way the way out again.
Think you know about the dash screws?
Currently chasing a rear end intermittent hollow "donk" myself, that appear to come and go with - temperature/acceleration/deceleration/braking/or just a bump in the road when it feels like it. . I cant tell, but all have been possible in my head at some point. I might just have to turn the stereo up for this one!
Good luck
Last edit: 23 Dec 2021 15:46 by Scimike. Reason: forgot fix
  • DrRobin
  • Platinum Member
  • Platinum Member
23 Dec 2021 15:55 #240759 by DrRobin
Thanks Mike,
You might have it there, three things different about yesterday's trip:
1) It was quite windy on top of the moors, a head wind coming back.
2) The missus was in the car, we have different music tastes and the stereo was off for the first half of the return journey, that is why I heard the hollow rattle.
3) I have DAB so the aerial is normally left push down. The DAB drops out over the moors so to allow the missus to continue to listen to her programme on the way down, I extended the FM aerial, but did it on the move and it was probably not all the way up.
I suspect it was the aerial, it had that sort of sound, wind/rain pushing past something causing vibration or possibly sucking air out of the aerial casing (venturi).
The aerial is all the way back down now, so I just need to find a head wind and get my Jimny up to 70mph to test to see if it has gone.
Good luck with the hollow dunk from behind your Jimny, it's not the caravan is it (joking of course)? I would suspect suspension (broken coil spring) or a bush wearing out. Then again it could be the exhaust or possibly it is....... (fill in the blanks with anything back there).
24 Dec 2021 06:46 #240764 by Lambert
On Dreadnaught I had a rattle in certain head wind conditions that I found to be the bonnet chattering. Adjusted the rubber wind out bung things and no more noise.
  • DrRobin
  • Platinum Member
  • Platinum Member
24 Dec 2021 09:08 #240766 by DrRobin
Thanks Lambert,
I will check the bonnet as the sound did appear to come more from the front than the aerial, but it did sound like air passing through something rather than a metal panel vibrating. My back door rattled until I adjusted the catch.
Just to make it harder to find of course it’s not doing it now.
Robin
Time to create page: 0.112 seconds
