Reverse light upgrades?
- Thank you received: 234
01 Dec 2021 23:27 #240434
by 300bhpton
Reverse light upgrades? was created by 300bhpton
Can anyone recommend a LED upgrade for the 4th Reverse light? I’m sure the standard light works. But it never seems very bright. Anyone managed to improve this.
02 Dec 2021 09:05 #240439
Replied by Soeley on topic Reverse light upgrades?
I did mine early on, big improvement of standard.
SEE HERE
The following user(s) said Thank You: 300bhpton
02 Dec 2021 09:12 #240440
I also went one step further later on with a small flood light mounted on the rear door that is switched independently
SEE HERE
I have another on the way and am thinking of mounting the to the rear gutter when I have swapped my up-and-over garage doo to a pair of side hinged doors. That will allow my to drive in the garage with roof bars still fitted (and possibly roof basket).
02 Dec 2021 21:33 - 02 Dec 2021 21:34 #240450
by Scimike
Replied by Scimike on topic Reverse light upgrades?
In the past I've fitted a flood / spotlight to some of my vehicles as done by Soeley. It's by far the best way to see what's happening behind at night when the standard light will not do.
I have no need at present on my Jimny, but would fit again if need arises. Simple to make it work with reverse or overide switch, great if you are working behind the vehicle in low light.
My 1960 Land Rover has one still, it's brighter than the two candle's up front
Last edit: 02 Dec 2021 21:34 by Scimike.
Time to create page: 0.089 seconds
