Air compressor
  • Danparry
10 Nov 2021 05:29 #239984 by Danparry
Air compressor was created by Danparry
Hey
I've got this portable compressor
I have a link below,
I want to hard mount it in the boot with anderson plugs,
My question is what guage wire would be recommended to run from the starter battery to the compressor in the boot?
The max amp draw is apparently 45amps
www.bcf.com.au/p/xtm-air-compressor-160l-150psi/580442.html
Cheers
10 Nov 2021 08:10 #239986 by Busta
Replied by Busta on topic Air compressor
6mm automotive cable is usually rated to 50 amps, but it depends on the temperature rating of the insulation. It should say on the packet.
10 Nov 2021 08:13 #239987 by Busta
It says in the ad that it comes with 2m of cable. Use the same size cable for your plug.
10 Nov 2021 10:10 #239989 by Roger Fairclough
Replied by Roger Fairclough on topic Air compressor
If you are going to mount the compressor in the boot as a permanent fixture, then you don't need Anderson plugs. 6mm cable will cope with 50 amps but because of the distance involved I suggest you use 7mm - rated at 57amps - as this will reduce voltage loss and heat build up. I have one of these compressors and the cable ( from memory, I have never used it ) is not suitable for a hard wired system. I suggest you remove the cable on the compressor system and re-wire with the new 7mm cable and fit a suitable fuse holder adjacent to the battery. Also make certain that the air hose will reach the front wheels and anything else you need to pump up.
Roger
10 Nov 2021 15:59 #239999 by DrRobin
Replied by DrRobin on topic Air compressor
Just to clarify when you say 6 or 7mm are you talking about the diameter of the conductor or the cross sectional area? I am assuming it is diameter as I haven't seen 7mm2 cable.
Standard cross sectional area cables are
6mm2  - 41A Approx 5mm diameter)
10mm2  - 57A Approx 6mm diameter)
16mm2  - 76A Approx 7mm diameter)
I would suggest 10mm2
A fuse might also be useful, cable of that size and the battery could supply a lot of current in case of a fault and this might cause a fire if no fuse is fitted.
Finally is the battery/alternator up to the current?
10 Nov 2021 17:55 #240003 by Busta
Sorry, I was talking mm2. I'd use something like this, but I'm more farm mechanic than auto electrician so I concur that bigger is probably better.  www.12voltplanet.co.uk/twin-siamese-batt...ble-2-x-6mm-50a.html
Time to create page: 0.110 seconds
