Possible Transmission Issue
- MDH
27 Oct 2021 12:20 #239656
by MDH
Possible Transmission Issue was created by MDH
Hi!
I bought my first car a few months ago and it’s a 2008 manual Gen3 Jimny Sierra! I brought my more mechanically minded friend to buy it with me and the car seems in pretty good condition overall.
The only problem I’m having with it is a bit of a grinding noise that only occurs while in gear at higher RPMs. The noise starts at about 2,500 rpm and slowly gets louder as RPMs increase. I’m pretty sure it’s making the noise in all gears and it’s hard to tell if it’s louder in particular gears because as soon as I make a gear change the car will obviously be sitting at a different RPM. The noise stops almost immediately after putting the clutch in (or if it’s still present at least get significantly quieter). I’m hoping it may be a transmission bearing or something but I’m really struggling and can’t seem to find my exact problem online!!
Cheers for any help!
- Thank you received: 2004
27 Oct 2021 15:16 #239659
Replied by Lambert on topic Possible Transmission Issue
Welcome to the forum. Is I a little light tinkling sound, or is it a more determined heavier metallic noise? The first one is probably a heat shield on the exhaust but the second is likely a gearbox bearing which your age Jimny is prone to. The gearbox is usually about £500 to repair depending on your location.
- MDH
27 Oct 2021 16:10 #239660
by MDH
Replied by MDH on topic Possible Transmission Issue
Hi and Thankyou!
It’s more of a heavier metallic whirling, I might be crazy but I feel like it’s loudest in 4th and quietest in 5th. Also I’ve just noticed that it’s primarily when accelerating.
I suspected it was probably a gearbox bearing but I’ve read so much conflicting information it’s very confusing. Also I know Jimmy’s can be prone to bad wheel bearings and one of the things I’ve read on the internet is bad wheel bearing can cause noise when accelerating?
- MDH
27 Oct 2021 16:54 #239661
by MDH
I posted a YouTube video to help diagnose the issue:
From description:
Slowly accelerating from 1st up to 5th gear. I put my foot on the accelerator and then took it off several times in each gear to show the noise difference when accelerating.
From description:
28 Oct 2021 16:24 #239696
by Scimike
Replied by Scimike on topic Possible Transmission Issue
Videos are never good for trying to pass on the "sound", everything sounds slightly metallic. I can't tell if that's just normal transmission noise or something wrong. I can hear a tinkling sound, but that may be stones hitting the body. Over to others with better hearing than me.
You can start by eliminating the wheel bearings. Jack the wheels off the floor and spin by hand. You are listening for the one that just sounds different to the others. If they all sound much the same then it's not wheel bearings. Also have a feel and a listen to the rear propshaft joints as you spin it, any play or noticeable noise is suspect.You can always compare to the front propshaft joints which tend to have little use.
Start with the simple (cheap) stuff and eliminate these first.
Good luck.
Mike
Good luck.
Mike
28 Oct 2021 17:02 #239699
Hmm wouldn't like to say that sounds horrible as it is so hard to tell. It's certainly not an immediate OMG noise but hard to say. Sorry.
Time to create page: 0.089 seconds
