Engine cut out
- GrahamJimny
10 Oct 2021 18:19 #239282
by GrahamJimny
Engine cut out was created by GrahamJimny
Hi, I topped up oil as it was on low point of dip.
This may be unrelated, but after drive back home 20 mins on motorway, I noticed a smell of petrol.
Pulling in, engine conked out, and a bit of smoke appeared side of bonnet.
I turned off engine, and noticed temp still was ok.
I drained the sump plug for a bit thinking this had been the problem, as the oil poured out I noticed it smelled of fuel!
I left it cool for an hour,
she started back up fine.
Any ideas?
Any ideas?
10 Oct 2021 21:17 #239284
by Scimike
Replied by Scimike on topic Engine cut out
Hi,
The oil level is probably unrelated, but I am assuming it's now happy and within the dipstick limits? The smell of petrol in the oil could be many things, but it's best to start simple.
It would help us if we had a general idea of the engine condition, is it serviced, clean fresh oil before the problem, how many miles etc.
Re the cut out -
Did you experience any running issues prior to it stopping, also assume you could not start it for the 20 minutes you let it cool down?
The top of the list on a Jimny is crank sensor shutting down with heat, but a little more info on how it was running would help.
Re the cut out -
- GrahamJimny
11 Oct 2021 08:36 #239292
by GrahamJimny
Replied by GrahamJimny on topic Engine cut out
I pretty much just bought the car and drove it 50 miles home. And seemed fine.
He said he did the brakes an serviced it but I take that with a pinch of salt. Maybe he changed engine oil, it looked clean.
Inside engine bay there was quite a bit of mud splash.
so yesterday I gave the front of radiator a hose down.
My friend opened the air filter and said theres your problem, but Im not convinced Ive seen a lot worse.
There is signs of gasket seal around the 'crank case' I think its called. My friend again is a motorbike nut, so he said thats alright but worth removing and doing properly.
The engine looks clean, and was running sweet, about 100,000 I think on clock.
Maybe I just give it another test run?
11 Oct 2021 09:25 #239296
by sniper
Replied by sniper on topic Engine cut out
Have a look at the second cat, the manifold cat has a habit of disintegrating and blocking the second cat.....
sniper
sniper
- GrahamJimny
11 Oct 2021 10:02 #239297
by GrahamJimny
I closed the bonnet of the car and engine cut out!
the positive battery terminal was touching bonnet!
- Thank you received: 679
11 Oct 2021 15:08 #239312
Replied by DrRobin on topic Engine cut out
It probably has the wrong sized battery installed (too tall, unless it is fitted in the wrong place), but the positive terminal should also have a cover on it to prevent short circuits.
As you also have a smell of petrol, I would get the battery terminal sorted quickly, it will produce a very large spark when it shorts out and that might ignite whatever petrol there is in the engine bay.
As for the oil smelling of petrol a quick Google search shows lots of potential reasons, including just short journeys.
Robin
Robin
Time to create page: 0.088 seconds
