G13bb wont run ):
  • crateAnt
06 Oct 2021 11:05 #239178 by crateAnt
G13bb wont run ): was created by crateAnt
Hi all! joined this forum page as a last hope for help. I've been building a gen 3 Jimny bush truck / comp truck. Been stuck on the engine for the last few months and have almost given up. It's a g13bb engine, that I rebuilt the bottom end on. (new crankshaft, bearings and caps).
The engine is now back in the half-built vehicle. Its got spark, fuel and compression. I've been messing around with the timing for so long now and can't figure it out. I believe I've got the cambelt set correctly now (valves opening and closing as should). Need help with ignition timing, if that so be the problem. I've bought and tried new coil packs, still wont run. The only last thing I cant think of is cam angle sensor?? Am I on the right track? please help.
Looking for any experienced people to jump on board helping me with this. Dont even know if this thread will be seen, but if so, please express your interest to help and I can get photos and more detailed explanations.
Thanks a lot if your reading this!
06 Oct 2021 12:05 #239179 by DrRobin
Replied by DrRobin on topic G13bb wont run ):
Hi,
I am sure someone on here will know exactly what the problem is and get you going, but a couple of quick questions:
1) The immobiliser has been known to cause problems, but then I wouldn't exepct to see a spark.
2) Do you have an OBD-II reader, that might give a clue especially if it is a sensor failed?
06 Oct 2021 12:41 #239181 by fordem
Replied by fordem on topic G13bb wont run ):
How are you checking for fuel?  Have you checked fuel pressure at the rail?  Have you checked for injector drive pulses?
Putting aside the fuel temporarily - if you have compression & spark at the correct time, it should run on starting fluid sprayed into the intake, and this can be one method of determining the problem area - if it doesn't run this way, the problem could be, as you're suggesting, ignition timing - you should be able to put a timing light on the #1 plug and look at the timing marks to see you're firing the correct plug at the correct time.
Time to create page: 0.108 seconds
