Consuming fuel.
25 Sep 2021 20:24 #238945 by Lambert
Consuming fuel. was created by Lambert
Have had to endure some motorway work today running around a few errands. Temeraire has been perfect and has recorded a world record i suspect of just under 46 mpg over 220 miles of mostly motorway but also through the centre of Leeds which was nice. Very impressed especially with the reports that the new e10 has a negative impact on mpg. I think that most of the benefits are a result of the very much lower engine speed afforded by the monstrous over drive in the automatic, 70 indicated (65gps) running about 3200 as opposed to 3800 in the manual.  All told I'm happy with 46 from a 1.3 automatic brick.
25 Sep 2021 20:36 #238946 by Lambert
Replied by Lambert on topic Consuming fuel.
It also lays my concern about how much fuel I use on a more regular basis to rest,as I'm prepared to accept that relatively slow short runs and off road work are genuinely causing the issues and it's not the car that is being unduly hungry. She is capable of sipping the juice when the conditions are reasonable.
25 Sep 2021 20:48 #238947 by Dan
Replied by Dan on topic Consuming fuel.
Although it might be contrary to what the motoring journalists reported, I think I might have had a slight increase in E10.
I went from 42mpg to 38mpg when I changed to AT tyres, but my trip computer now believes I'm getting 40mpg.
I'm not entirely sure I believe it.
25 Sep 2021 21:43 #238949 by Scimike
Replied by Scimike on topic Consuming fuel.
I have keep a log of the miles every tank gives and have done since the first day of ownership. The MPG obviously varies with use, lowest I have seen is 28mpg, highest is 46 mpg, but you can't tell on just one tank.  ( M13A MT).
Even what you consider to be the same use will give different results, many factors come into play. So far I have seen little evidence that super expensive or cheap supermarket petrol has had any impact. I don't expect to see any difference on E10, but I need to put a lot more tanks through before I get any results.
I don't do it as I am concerned of the actual MPG, it's a means to spot any running issues early, but as it's a Suzuki it's been reliable since day one. I have averaged about 36mpg over the years, which is about the reported expected MPG given on the web.
26 Sep 2021 04:52 #238950 by Lambert
As I have said before I am not to concerned about the actual figure this is more a relief/confidence that my regular pilgrimage to the North of Scotland isn't going to see me hemorrhage money uncontrollably.
On a related note I noticed that one of my local esso garages has decided to take the unfortunate step of increasing their prices as a result of the current panic buying, virtually overnight it went from 139.9 to 142.9 which I suggest is gross profiteering. It also has the added benefit of making me unlikely to use them again.
26 Sep 2021 09:06 #238954 by Dan
I learned recently by doing research on finding E5 for my motorbike that tesco have a price differential on super plus unleaded.
On my local forecourt standard E10 is 133.9 whereas they sell momentum for 140.9, I believe the 7p difference is their standard.
I shopped around one day and found that Shell and a tesco express Esso were considerably more expensive, given that these companies buy in very similar product from refineries, I'm not certain for my needs, buying branded fuel will make a worthwhile difference.
Time to create page: 0.094 seconds
