4WD flashing
- Jemjem
20 Sep 2021 04:56 #238814
by Jemjem
4WD flashing was created by Jemjem
Hey everyone! I have a 2014 Jimny and got to test her out at Mt Mee on the weekend. It appears however, they we may have gone a little hard on her and now the 4WD will not engage. The light continuously flashes and there is no noise to indicate it has "clicked" in. Wondering if anyone else has had the same problem and what you did to fix it? Cheers!
- Thank you received: 679
20 Sep 2021 13:15 #238822
Replied by DrRobin on topic 4WD flashing
The flashing means that the 4WD hasn't engaged (which you have already figured out). There are a number of reasons why this might be the case, a problem with the vacuum, faulty hubs or even a transfer box problem.
There is a good wiki page here
www.bigjimny.com/mediawiki/index.php/4WD...ion_system_operation
This describes the system of what needs to happen and suggests some common faults. There is quite a lot to check.
20 Sep 2021 13:20 #238823
The link at the bottom of the wiki pages shows how to diagnose the fault.
www.bigjimny.com/mediawiki/index.php/4WD..._failure_diagnostics
This part seems most likely
Transfer box is in 2WD. Then 4WD is selected.
However, the 4WD light flashes and remains flashing.
The flashing is caused by the 4WD controller thinking
that the vacuum system has failed.
5
6
7
8
Vacuum pipes blocked
Vacuum/air leaks from the system
Valve solenoid failure (VSV2)
Pressure switch failure
5
6
7
8
20 Sep 2021 15:58 #238829
by Scimike
Replied by Scimike on topic 4WD flashing
The transfer case has 2 cables on a plug that are a prime target to get damaged if you off-road.
Stick your head under the vehicle and check all is well in this area.
After that it follow the fault finding charts!!
- lookonimages
- Thank you received: 72
20 Sep 2021 17:57 #238831
by lookonimages
Replied by lookonimages on topic Re:4WD flashing
Agree this little electrical plug on transfer case has produced many a headache. Check it first.Scimike wrote: The transfer case has 2 cables on a plug that are a prime target to get damaged if you off-road.
Time to create page: 0.114 seconds
