Rear jimny issues
- Ryan9722
15 Sep 2021 22:40 #238655
by Ryan9722
Rear jimny issues was created by Ryan9722
Hi,
i recently bought a 2009 suzuki jimny and wiyh a manual gear bought. One morning i moved off in 1st gear climbing up a gentle slope, when i was at the top of the slope i clutch i accelerated a little to shift to second gear but in accelerating i started feeling the back of the vehicle shaking really back anf the vehicle was hesitant to move. I then clutched in and selected the reverse gear and heard a stange noise like something is breakimg evrrytime i select reverse an gentle raise my foot off the clutch.
the vehicle still have a heavy vibration in the back when trying to accelerate and the noise in the wheel when i select reverse.
- Thank you received: 2004
16 Sep 2021 04:07 #238656
Replied by Lambert on topic Rear jimny issues
Welcome to the forum. First off I would suggest you crawl under the car and check that the rear output shaft is not able to move horizontally or vertically, this would indicate worn or damaged universal joints. Next I would suggest trying to lift or otherwise move the transfer box as this will indicate if the aluminium locating brackets have cracked or broken. After that I would suggest trying to lift the output end of the main gearbox vertically as that will show if the rubber mount for that has failed. All these options are the simplest to rectify and if it's not these diagnosis becomes more difficult.
- Ryan9722
16 Sep 2021 12:56 #238661
by Ryan9722
Replied by Ryan9722 on topic Rear jimny issues
Thanks i will check under the vehicle today
16 Sep 2021 17:36 #238669
by facade
Replied by facade on topic Rear jimny issues
Check the rear axle too, they can break where they are welded next to the diff. The crownwheel bolts sometimes come loose if the noise and play are within the axle.
- Ryan9722
16 Sep 2021 22:18 #238692
by Ryan9722
Ok i found that the imediate propeller shaft universal joint broke i will install tomorrow and see if it is fixed
- Ryan9722
17 Sep 2021 19:15 #238731
by Ryan9722
Do they manufacture the propella shaft universal joint for 2009 jimny
Time to create page: 0.110 seconds
