Towing a caravan
- Thank you received: 1945
08 Sep 2021 15:47 #238353
Replied by Lambert on topic Towing a caravan
Well the Jimny is much more stable at full load than ever my old Cherokee sport was at its full load. That old bus was very wobbly. Like I said earlier I have been towing for like 40 years now so I have a reasonable expectation of whatisto beexpected. The other thing I like about the Jimny is because of the lack of power it demands that you as a driver are actively involved with what you are doing. With leviathan it's only once the big Big trailer is actually loaded that you start to realise there's something on the back. That in a way I find slightly disconcerting as it's easy to forget and get into trouble.
08 Sep 2021 16:18 #238355
That's correct however there are certain complications in home building trailers, they are supposed to be iva tested and have individual chassis number etc. It's a bit of a nightmare doing it properly. However if you have an existing trailers it's a bit of a grey area where new build starts and refurbishment ends. There is quite a lot of reading on this in the Internet.
Scimike if i go and make a camper/trailer from my spare Jimny body and chassis if i keep the construction below 350 kg does that mean I will not need to have brakes on it.Don't feel there is any real contradiction, it clearly states 1300kg braked and 350kg unbaked on the official V5 form. I assume this will be the go to place for any "hello, what's all this then" police officer. I always believed the 50% unbraked / 80% braked is a rule of thumb, something used when the loading is not stated by the manufacturer or on the V5 - ie older vehicles etc.
Rant away if I am wrong,
The chassis plated total train weight less the maximum vehicle weight leaves 1300kg for trailer load, and I guess that's where the V5 figure is from.
What is up for debate is why Suzuki recomended 350/450kg for towing loads and is the 1300kg allowed actually a good idea on the back of a Jimny
08 Sep 2021 16:29 - 08 Sep 2021 16:30 #238356
by Scimike
Replied by Scimike on topic Towing a caravan
What Lambert said +1.
The laws tighten up on home built trailers, so much so when I looked into this for a small teardrop caravan I wanted to make, I considered purchasing a professionally made frame with certification as a base. Exactly how they prove when / who made it is the great u known, its all age related, but I personally did not want to take a chance.
Last edit: 08 Sep 2021 16:30 by Scimike.
- Dirtbird
08 Sep 2021 22:52 #238372
by Dirtbird
Replied by Dirtbird on topic Towing a caravan
Had a Jeep Cherokee Sport 2.4 Diesel. Gave me a lot of trouble, ended up with a bad diesel knock and got rid of, traded it in for a Hilux single cab, and never looked back.
- Dirtbird
08 Sep 2021 22:54 #238373
by Dirtbird
A mechanic told me once you could tow a trailer with a Micra provided you wet slow enough. Basically know the limits and stay within them.
09 Sep 2021 11:27 #238386
by Busta
Replied by Busta on topic Towing a caravan
Time to create page: 0.215 seconds
