Towing a caravan
- Dirtbird
08 Sep 2021 10:45 #238341
by Dirtbird
Replied by Dirtbird on topic Towing a caravan
Lambert are you using your Jimny farming?I tow a lot with my gen3 and as long as you accept it can be quite slow progress up big hills then you will be fine. The caveat there is that the windage on a caravan is going to be quite noticeable compared with a livestock trailer but equally you won't have any issues with your load moving about as you drive. The additional power of the 1.5 will also help.
- Thank you received: 1931
08 Sep 2021 11:08 #238344
Replied by Lambert on topic Towing a caravan
Yes I am. Its brilliant! It's like a quad bike and a defender 90 had a baby. I couldn't cope without it.
- Dirtbird
08 Sep 2021 11:32 #238345
by Dirtbird
That great to hear, it's the main reason I'm putting so much time and effort into my rebuild . Hope to use it to lick rushes and other farm-related chores, cutting timber, etc.
08 Sep 2021 11:49 #238346
I'm finding that the automatic gearbox is such a superior drive train to the previous manual especially with the load on the back of a trailer, if the terrain dictates you can lock out the higher speed as you need or if it's easy going you are always in the right gear in traffic and such. It allows you to pay more attention to your surroundings than having to think about which gear you need. It's also way better for shunting as there's no clutch to burn.
08 Sep 2021 15:01 #238350
by Scimike
Replied by Scimike on topic Towing a caravan
Don't feel there is any real contradiction, it clearly states 1300kg braked and 350kg unbaked on the official V5 form. I assume this will be the go to place for any "hello, what's all this then" police officer. I always believed the 50% unbraked / 80% braked is a rule of thumb, something used when the loading is not stated by the manufacturer or on the V5 - ie older vehicles etc.
Rant away if I am wrong,
The chassis plated total train weight less the maximum vehicle weight leaves 1300kg for trailer load, and I guess that's where the V5 figure is from.
What is up for debate is why Suzuki recomended 350/450kg for towing loads and is the 1300kg allowed actually a good idea on the back of a Jimny
- Dirtbird
08 Sep 2021 15:40 #238352
by Dirtbird
Scimike if i go and make a camper/trailer from my spare Jimny body and chassis if i keep the construction below 350 kg does that mean I will not need to have brakes on it.Don't feel there is any real contradiction, it clearly states 1300kg braked and 350kg unbaked on the official V5 form. I assume this will be the go to place for any "hello, what's all this then" police officer. I always believed the 50% unbraked / 80% braked is a rule of thumb, something used when the loading is not stated by the manufacturer or on the V5 - ie older vehicles etc.
Time to create page: 0.417 seconds
