Fuel consumption?
25 Aug 2021 03:06 #237850 by Lambert
Fuel consumption? was created by Lambert
Ok so I am a few months into ownership of my automatic and I have noticed that the fuel consumption is quite exceptional when using 4x4 low. The consumption in 4x2 is very similar to what I expected from my last one but the difference between the two in low really is drastic. Don't worry I still stare into the distance when I'm filling up it's not a problem, I'm just wondering if Suzuki altered the fuel map in these later ones to improve torque or something?
25 Aug 2021 07:00 #237852 by lightning
Replied by lightning on topic Fuel consumption?
Are you saying that the new one is more, or less economical in low range?
25 Aug 2021 08:53 #237854 by saxj
Replied by saxj on topic Fuel consumption?
My Gen 4 Auto uses around 20l/100km (12mpg) in low range
25 Aug 2021 09:31 #237856 by Lambert
Replied by Lambert on topic Fuel consumption?
I'm saying that Temeraire, my 18 plate uses more fuel than Dreadnaught my 11 plate even though the only difference between the engines is euro 6 vs euro 5.
12 to 15 mpg sounds plausible in low range especially being the automatic. Don't get me wrong I don't mind especially as it just seems to be unstoppable and very strong in low range, I was just curious if it were entirely a function of the automatic gearbox being less economical or whether the ecu is reprogrammed to deliver more fuel in low range?
25 Aug 2021 12:58 #237860 by 300bhpton
Replied by 300bhpton on topic Fuel consumption?
I'd have thought the autobox would play a fairly big part of it. I'm guessing it doesn't lock the torque converter up, so you will essentially be using more revs and throttle than you would otherwise with a manual gearbox.
25 Aug 2021 16:50 #237864 by Lambert
Not noticeably using more revs than the manual it's still changing gear and keeping the revs down like it does round town it's just at a lower forward speed which is what I want for herding the sheep. I'm sure it will normalise me in a few more months. Of course the other issue could also be because of the time of year Temeraire has come into service, we have been busy as it's been the leader to sales season which means long days herding and towing unlike autumn and winter when things are calmer. Curiosity killed the cat after all!
Time to create page: 0.096 seconds
