Antenna Replacement gone wrong
- AndrewKotze
08 Aug 2021 17:49 #237412
by AndrewKotze
Antenna Replacement gone wrong was created by AndrewKotze
Hi All. This is my 1st time on the Forum so please excuse any mistakes.
I have a 2013 Jimny and started off replacing my Antenna today without seeking any advice or watching any YouTube Videos. How difficult can it be?
I found the place under the dash where the Antenna plugs into the harness and unplugged it. Then I removed the 2 screws on the roof and pulled the Antenna out. Then I pushed the new Antenna down the channel, but I couldn't find the other end when I looked under the dash. Now, this is when I started to seek advice online. The 1st Video showed me that I should have tied the old Antenna to a rope BEFORE pulling it out BUT I DIDn't.
Please help. Must I now strip the whole dash?
I've been looking for the answer online but just found many articles on the correct way. Please help - surely I could not have been the 1st guy to make this mistake?
08 Aug 2021 18:56 - 08 Aug 2021 19:00 #237413
by Scimike
Replied by Scimike on topic Antenna Replacement gone wrong
Hi and welcome.
No you don't need to strip anything down. The cable will make its way down the A pillar and end up behind the front speaker in the foot well. Remove the plastic cover shown in the photo and try pushing it down again. It may be easier to send a single core cable down first, attach your Ariel and pull it through.
Get your head in the foot well (hoover out optional) with plenty of light and get someone to jiggle / push it down, you will see it eventually.
I passed a wire down to feed my Light bar, so it can be done.
It's behind you, or at least behind this panel
Last edit: 08 Aug 2021 19:00 by Scimike.
The following user(s) said Thank You: AndrewKotze
- AndrewKotze
08 Aug 2021 21:40 #237425
by AndrewKotze
Replied by AndrewKotze on topic Antenna Replacement gone wrong
Thank You so much Scimike. Has anyone made a YouTube Video of this fix?
You are a lifesaver!
- Thank you received: 679
09 Aug 2021 11:26 #237439
Replied by DrRobin on topic Antenna Replacement gone wrong
Unfortunately the wire is always black, which doesn't show up very well. If you can get hold of reasonably stiff wire in red or other bright colour it will be easier to see.
Alternatively wrap a bit of red tape round the end of the new antenna cable, not only will this make it easier to see with the torch, but if you put it over the plug it will stop the plug catching on anthing and getting stuck.
Hope that helps
Robin.
Hope that helps
Robin.
Time to create page: 0.149 seconds
