just an idea
- Roger Fairclough
Topic Author
- Thank you received: 225
04 Aug 2021 10:32 #237291
by Roger Fairclough
just an idea was created by Roger Fairclough
In my LC and Gen.2 I covered about 250,000 miles of mixed roads, both surfaced and rough.
And in all those miles I did not have a puncture!
But I still carried a spare wheel and as the tyre size grew it, and the wheel got heavier and put more pressure on the hinges and latches which promoted wear and noise.
I also carried a decent quality electric pump and a repair kit which were never used.
Now you could go the whole hog and dump the spare and hope the pump and repair kit will suffice but what if you rip the sidewall open?
Firstly, don't try and stuff the tyre with dry grass, it will probably catch fire. At least that's what happened in Scotland in my Fiat X1/9.
Or, you could obtain either a run flat tyre and wheel or a normal but smaller tyre wheel combination purely to get you home.
Comments on a postcard please.
Roger
Roger
- Thank you received: 2004
04 Aug 2021 12:43 #237292
Replied by Lambert on topic just an idea
Not often but I have had nails and stuff in tyres and always been happy I have a spare. Only a get me home but still a correct spare.
- Thank you received: 679
04 Aug 2021 12:48 #237293
Replied by DrRobin on topic just an idea
I had run-flats on 3 different BMWs, I was unlucky enough to get two puntures in the first 2 cars (both 4wd), one in the front and then one in the rear.
The front made the car so unstable, I turned round and took it home as I was less than 1m from home, I can honestly say it was very scary. The one in the rear didn't feel very good either. As for driving at up to 50mph for 50 miles on run-flat with a punture, I wouldn't.
All three BMWs came with a can of sealant, I used two of these, they sealed the tyres up enough to get to a garage. Run-flats are not repairable at the garage, so you just junk the tyre and they cost more. The sealant works just as well on non-run-flats, so I don't see the point of them.
I won't be having run-flats again, the sealant yes or maybe just AA/RAC membership.
For me though I would prefer to carry a spare, preferably a full size one, I am not bothered about the weight.
Robin
Robin
04 Aug 2021 18:54 - 04 Aug 2021 18:56 #237301
by Scimike
Replied by Scimike on topic just an idea
It's not too much trouble carrying a spare for me. Not needed one for the last 20 years, but two weeks ago picked up a 6mm diameter P clip and chain thanks to local road works and careless workers. Quick tyre swap and on my way again. I doubt any amount of magic fixing goo was going to plug the hole, it's was an "only just" repair at a professional tyre fixer's.
That said if weight is your issue how about a lighter tyre as a spare, a space saver if you will. Just get the smallest width that's close enough to your diameter. Don't need to be exact as it's not permanent 4WD.
Last edit: 04 Aug 2021 18:56 by Scimike. Reason: Auto correct
04 Aug 2021 20:20 #237303
by lightning
Replied by lightning on topic just an idea
l've always wanted a Fiat X1/9 since one went past my school while l was walking home in the 1970's
Trouble is, l don't like the "big bumper" 1500 and the 1300 is practically extinct.
05 Aug 2021 07:24 #237313
by Busta
Replied by Busta on topic just an idea
I'd sooner replace the door hinges and catch every 15 years than run without an adequate spare tyre.
Time to create page: 0.111 seconds
