AC sound problem
  • MGADIR
18 Jul 2021 08:46 #236771 by MGADIR
AC sound problem was created by MGADIR
hi, my jimny 2015 has a problem, when i accelerate
or give gas on "n"
there is sound and i see the ac compressor stops for second and when it stops , i hear the sound.
(second 9 in the attached video).
click here to see the video
18 Jul 2021 08:57 - 18 Jul 2021 09:01 #236772 by lightning
Replied by lightning on topic AC sound problem
Have you checked the A/C to see if it's low on gas?
Also, l believe that on some cars the A/C will disengage when you are accelerating fast in order to improve engine power to the wheels, as the A/C compressor uses between 1-4bhp
But it shouldn't keep switching in an out, it may be low on gas.
A/C loses up to 10% of its gas every year. Once it gets below around 60% it may not work.
Last edit: 18 Jul 2021 09:01 by lightning.
The following user(s) said Thank You: MGADIR
  • MGADIR
18 Jul 2021 10:36 #236773 by MGADIR
Replied by MGADIR on topic AC sound problem
Thanks for your fast replay. The gas is excellent And last tear i filled it
Do you have idea for the sound ?
18 Jul 2021 11:06 #236775 by lightning
lt sounds like the drive belt is slipping, have you checked the belt tension, or replaced the belt?
ls the A/C still working?
18 Jul 2021 14:37 #236779 by Lambert
Replied by Lambert on topic AC sound problem
The noise is definitely the drive belt slipping. It could be because the belt is not correctly tensioned or it could be the ac pump is beginning to seize which in turn could be a failing bearing in the pump or the system is somehow over pressure. I would suggest belt tension first as mentioned above.
  • MGADIR
19 Jul 2021 12:24 #236804 by MGADIR
Yes the ac is still working
Time to create page: 0.144 seconds
