Going up big dunes
- hai88
25 Jun 2021 16:35 #236143
by hai88
Going up big dunes was created by hai88
Hey everyone!
I have a 2017 Jimny which I love very much. I have went on numerous technical trips but only one of them included big dunes.
I really want to know - what is your formula for going up big dunes?
I have let my tyres down (MT in standrd size) to 10 psi which is roughly 0.7 bar. Im afraid to go lower to avoid getting the tyre of the rim.
I have tried going in low range, 2nd gear, 1st gear and in high range in 2nd.
Problem is, in low range, the car isnt fast enough to keep momentum up the dune.
In high range the car is fast enough but power is cut down due to stability control engaging over 40 km/h even if its been turned off.
I read somewhere you can disconnect the plug (somewhere behind the dashboard) to have the system disconnect completely but I just wanna go up some big dunes without buying a 4l land cruiser.
I would love for some advice!
Thanks!
Thanks!
25 Jun 2021 19:02 #236146
by Busta
Replied by Busta on topic Going up big dunes
Use 3rd gear low range?
- hai88
25 Jun 2021 21:21 #236152
by hai88
Replied by hai88 on topic Going up big dunes
Hey thanks for the reply.
It brings me back to the fact that spinning wheels on the soft sand will cause the system to engage and make me lose power to the spinning wheels.
I also read that you shouldnt drive fast on 4wd-L but Im here to learn so Im open to any bit on information
- Thank you received: 706
26 Jun 2021 06:35 #236154
Replied by jackonlyjack on topic Going up big dunes
The following user(s) said Thank You: hai88
26 Jun 2021 07:30 #236155
by Keithy
Replied by Keithy on topic Going up big dunes
250 HP diff locks and remove all electronic "aids"
- hai88
26 Jun 2021 08:56 #236157
by hai88
Thanks for the ideas!
I think Ive found the answer, like Keithy wrote, about removing aids.
Someone wrote about ESC service mode that you can have a wire short the plug and then it disables it until you start the car again.
I saw a few pictures but have no experience in such stuff so Ill go dig a little bit more.
If someone has a guide for it Ill be happy to read
Thanks again!
Thanks again!
Time to create page: 0.117 seconds
