Air Con.......Gone
  • Tedster
06 Jun 2021 21:08 #235635 by Tedster
Air Con.......Gone was created by Tedster
Any Ideas ?    2009 low mileage Gen3. Purchased in cold weather spell, hot weather arrives . no air con. Took to local trusted garage that have the proper re-gassing set up. Vacuum test ok ,re-gassed working fine. I collected the car on a cold afternoon and drove 1 mile to home without the air con switched on. I didn't use the car for about three days, when I did start it there was a loud screeching noise like a slipping fan belt which carried on until I blipped the throttle which calmed it down , there was also a faint burning smell (similar to burning clutch ) . The car is now displaying weird noises like worn out bearings, related to engine revs not road speed ( A/C pump ?) and gurgling liquid sounds . Engine Temp remains rock solid and the car drives perfectly OK.
Apart from the basic principles I am not aware of the fine details of how air-con works, It's going back to the garage for investigation in a few days , but if anybody out there has a bit of expertise let me know.
Thanks for reading.
06 Jun 2021 21:09 - 06 Jun 2021 21:10 #235636 by lightning
Replied by lightning on topic Air Con.......Gone
Sounds like A/C compressor failure.
Last edit: 06 Jun 2021 21:10 by lightning.
The following user(s) said Thank You: Tedster
06 Jun 2021 21:24 - 06 Jun 2021 21:27 #235637 by Scimike
Replied by Scimike on topic Air Con.......Gone
The screening will be the AC compressor electric clutch or drive belt slipping. Mine did this when I recharged my own AC, but note I did 100s when I worked at halfords, so this was not my first go. I used the same kit and the same principles I had used before, but it effectively overloaded the AC compressor before I got to the "normal" low pressure reading. This resulted in the clutch slipping.
So something appears different on my Jimmy AC, so much so I dumped some pressure to get the system spinning again. If I get chance I hope to take a look at a working system at the Jimmy meet and maybe use a different method to charge.
Not saying your garage did it wrong, but I am aware of another who had a pipe fail after a garage regas and I am unhappy with the load a standard charge puts on the system. Its possible my AC has an underlying fault, but I don't believe so at this stage. Its also a 2009.
Last edit: 06 Jun 2021 21:27 by Scimike.
  • Tedster
06 Jun 2021 21:28 #235638 by Tedster
Replied by Tedster on topic Air Con.......Gone
Thanks very helpful
06 Jun 2021 21:29 #235639 by DrRobin
Replied by DrRobin on topic Air Con.......Gone
The air con gas acts las a lubricant so when you loose pressure the pump tends to seize up and then of course the belt slips.
I would get them to check pressure on the air con system, if it is down then you probably have a small leak somewhere.
Robin
06 Jun 2021 22:58 #235640 by Keithy
Replied by Keithy on topic Air Con.......Gone
Who knows what they did....I like to have the system vacuum purged and leak tested prior to having the correct amount of oil and gas added.
If not vacuum purged it could have water within.....simple science tells you what happens when it's repressurized.
Time to create page: 0.094 seconds
