4wd
18 May 2021 11:09 #235173 by mag
4wd was created by mag
I know this has been asked loads of times but afyter 4 yrs of jimny ownership , I`ve lost 4wd  !!!  , 4wd light illuminates ( not flashing ) Can hear a " clunk " when engage 4wd ( not loud but can hear it ) but with 1 front wheel in air and 4wd engaged , i can easily spin the wheel , tried other side , exactly the same , I assume i have a vacuum leak but why no flashing green light on dash ??
18 May 2021 11:57 #235175 by Lambert
Replied by Lambert on topic 4wd
It could be a blocked line instead of a leak as such. Have you ever done work on the knuckle, is it packed with grease, this can cause problems.
18 May 2021 15:01 - 18 May 2021 16:16 #235180 by mag
Replied by mag on topic 4wd
found small split at end of 1 hose where it connects to nipple on passenger wheel , seems ok now ( hopefully !! )out on sunday on a trip with 3 others , after that , have time for a proper look over it , never realised how many hoses etc make it work , all seem secure
If i decide to replace all hoses etc , is it 3mm or 4mm internal diameter hose that fits the nipples on the car ?
Last edit: 18 May 2021 16:16 by mag.
  • justintime441
19 May 2021 03:33 #235190 by justintime441
Replied by justintime441 on topic 4wd
another option is to just ditch the vacuum system so this never happens again and go to manual hubs. Can be as cheap as $100
19 May 2021 15:39 #235206 by mag
prob just going to stick a bolt through the hub and permanently lock the hubs as do little on road miles , cost close to zero !!!
20 May 2021 19:33 #235239 by Busta
Replied by Busta on topic 4wd
It's 4mm hose you need. I've used pvc aquarium hose - it was £7 for 10m. I've routed it down the brake hoses rather than along the axle so it is well out of harms way. It's only 2 hoses to each hub- not complicated at all really.
The following user(s) said Thank You: mag
Time to create page: 0.101 seconds
