Tpms sensors
17 May 2021 07:43 #235136 by Lambert
Tpms sensors was created by Lambert
Just a quick one. The tpms sensors, are they individually coded to the car the wheels came on or can they be swapped without getting upset. I am waiting to equalise the tyre wear between 10 tyres on 2 cars one of which is going to be doing twice or more the miles of the other and I don't want to be left with some with full tread and others bald.
17 May 2021 08:03 - 17 May 2021 08:04 #235138 by RainerK
Replied by RainerK on topic Tpms sensors
When I changed all tires on my 2015 Jimny I had to do nothing regarding the TPMS and when I rotate the tires there was also nothing to do. The TPMS recognized the sensors on its own. Therefore I would think that there is no individual coding that has to be done. Before rotating I made sure that the spare wheel also has a sensor.
Last edit: 17 May 2021 08:04 by RainerK.
17 May 2021 08:04 #235139 by mlines
Replied by mlines on topic Tpms sensors
Assuming the Gen3 is the same as the Gen4, it is an automatic learning system and is reset every time you stop for around 15 to 20 mins.
Therefore it re-learns which wheel is which. So if you were really quick changing wheels around it is possible for the "wrong" wheel to appear on the wrong corner but this is unlikely and will rectify itself.
The rectification should occur within 10 minutes of stable driving.  This is because the system goes into a 10 minute learn cycle. After this it settles to a background learning rate. I set off on a fairly long journey to Bristol in our Gen4 and it failed to learn the wheels for 90 minutes. I can only assume this was because of unstable driving at the start (local rush hour stop/start) and then not reading the sensors very well during the background learning rate. The sensors work on a little battery in each sensor on 432Mhz so any other transmissions on this frequency will jam them. Of all our TMPS cars, the Jimny system is the most unreliable despite our Swift having an IDENTICAL system,
17 May 2021 08:07 #235140 by Lambert
Replied by Lambert on topic Tpms sensors
Ok cheers. So it's just a matter of putting whichever wheel in the best position and going for a pootle for half an hour. Excellent thanks.
Time to create page: 0.090 seconds
