Replacing the back box
- CJ Davies
11 May 2021 13:39 #234973
by CJ Davies
Replacing the back box was created by CJ Davies
11 May 2021 14:49 #234975
Replied by jackonlyjack on topic Replacing the back box
IMO 2 options hacksaw or try to tighten them till the bolts snap
On the other hand you could by a grinder for around 20 quid
you'll still be saving money and have one for next job
- CJ Davies
11 May 2021 15:17 #234976
by CJ Davies
Replied by CJ Davies on topic Replacing the back box
Alas I'm in a third storey flat with no garage, so I can't run power for a cheap grinder! I have 18V DeWalt batteries but they want £110 for a bare grinder to plug them in to.
I'm soaking the nuts in WD40 atm (half expecting them to completely dissolve). It looks like this eBay kit for £60 has everything I could possibly need? I'm assuming if I get the bolts out it's simply a case of hooking the new box onto the hanger at each end, fitting the new gasket between the flanges & then just replacing the two bolts? All while trying not to inhale too many rust flakes, ofc.
11 May 2021 18:02 #234984
by Michael83
Replied by Michael83 on topic Replacing the back box
Get a hacksaw and some spare blades, give the bolts a smack with a hammer, mine snapped off when I did my exhaust. If that don't do it hacksaw them off. It will be done before you know it.
Loads of back boxes on eBay for about £50 tops. You need a 42mm Id ring gasket too or it will leak loads of water from the flange.
A clamp on 12" X 5" 42mm Id straight through muffler will bolt straight on too with the flange cut off. Got mine from 'custom exhausts' on eBay.
Have fun mate
Have fun mate
11 May 2021 18:24 #234986
by Scimike
Replied by Scimike on topic Replacing the back box
Nuts aside, I found it easier to replace my rear silencer with the rear bumper removed, it gave better access without the need inhale rust flakes.
Not essential and may give more nut trouble if your bumper nuts will not come apart, but mine did easily enough.
Mike
Mike
11 May 2021 21:46 - 11 May 2021 21:47 #234991
Replied by yakuza on topic Replacing the back box
Good tip Scimike, Remove the bumper for access, especially if you got a trailer hitch. Much easier access. Depending on brackets, hitch and back box end pipe design, you might need Some lift like a Jack or ramps or one wheel on the side walk to mangle it in/out.
Last edit: 11 May 2021 21:47 by yakuza.
