Re:Ice question.
- Thank you received: 2004
You can get some neat little class D amps that will run happily from 12v, and you have already found the bluetooth reciever device you would need. I run huge alpine class D under the seats, but am thinking of weight reduction with this as well as the iPad for navigation and tunes
Nice tip Lambert might check it out for my jimny thanksLambert wrote: The mood is upon me to investigate running a head less system in Dreadnaught. I have a very nice Genesis amplifier which in a most basic way I could separate the 4 channels from a headphone jack and simply plug in my phone which is basic and in reality all I need it to do. Only downside is I don't like continuous use of the jack as the hardware on Samsung phones is not massively robust. Instead I prefer Bluetooth and wireless charging. Sony do a smartphone adapter that allows you to control functionality via Bluetooth that then presents as a jack for use in oe systems which would work but it still requires jack to rca and then splitting front and back. My electronic expertise won't run to making a custom Bluetooth to 4.1 channel rca breakout board. The only other thing that just occurred is to look for a half din preamp eq with Bluetooth. Just off to amazon for a minute.
Might be the answer for you Lambert? I'm going to try rigging it up to the big alpine v12 amps and see how it goes, then bye-bye head unit
