Gen4 rust
12 Apr 2021 20:23 #234423 by Micheal
Gen4 rust was created by Micheal
Hi folks
Had slow puncture so swapped wheel for spare today. Was disappointed to see the mounting brackets behind the spare wheel were already rusting. The car is a late 2018 SZ4.
Are we supposed to take of all these metal bits and get them galvanised?
Any thoughts?
12 Apr 2021 21:14 - 12 Apr 2021 21:15 #234424 by Scimike
Replied by Scimike on topic Gen4 rust
Hi,
Don't know what the rust warranty is like, usually worthless unless it's a hole, but worth a read or a visit to the dealer and see what they say.
As the replacement (if they do anything) is going to be just as bad I favour DIY solution.What's the finish, painted or plated?
I guess it's one shot paint, the favoured finish for black brackets and suspension parts.
My G3 spare wheel carrier was painted (one shot) black. I removed and treated the surface rust and resprayed, etch, prime, black wheel finish and lacquer. Took a day or two but so far this finish is lasting well. The other option is to take it to an industrial coaters and get it blasted and enamelled. Try to go to one that finishes motorcycle frames etc, they tend to do a much better job. Done properly it's a much more durable finish, done poorly it's worse than paint.
Or get it galvanised!
Last edit: 12 Apr 2021 21:15 by Scimike.
12 Apr 2021 21:14 #234425 by lightning
Replied by lightning on topic Gen4 rust
l would complain to your dealer, it's possible to produce painted metal parts that last longer than three years before going rusty.
Although it would be a long time before the rust turned into actual corrosion. Just look underneath any car over two years old, all the metal parts are generally covered in surface rust.
  • Axholme Lion
13 Apr 2021 10:09 #234432 by Axholme Lion
Replied by Axholme Lion on topic Gen4 rust
Go to the dealer, it will be covered under warranty.
I had a wheel bolt which went rusty and they swapped it straight away.
13 Apr 2021 12:18 #234437 by DrRobin
Replied by DrRobin on topic Gen4 rust
It's a bit sad that the bracket has rusted so quickly. I didn't think rust was a problem on modern cars until I got a Jimny.
If the dealer won't play ball, my advice, get a tin of black Hammerite, wire brush the bracket first and brush paint a couple of coats on to it, you will never have to worry about it again.
I have just bought a 1L tin of the stuff (about £9) to paint my motor bike stand and brake pedal, the old Hammerite had been on for 25 years and took some bringing off with a wire brush.
Robin
13 Apr 2021 13:23 #234440 by RainerK
Replied by RainerK on topic Gen4 rust
I had the same issue and what I asked myself was, how does the rest of my Jimny look?
After inspecting, repairing one spot underneath the bumper I got my complete Jimny corrosion protected with fat, inside, outside, underneath, .... .
