Jimny & Vitara Brezza
- lookonimages
- Thank you received: 72
10 Mar 2021 18:03 #233623
by lookonimages
Jimny & Vitara Brezza was created by lookonimages
We have had the Suzuki vitara brezza released in SA.
They say it has same engine as jimny. I believe this brezza have much better gearing for driving highways.
Now my question. What is your opinion on fitting the Brezza gearbox onto a jimny. Sure as hell there would be a huge ref drop in 5th gear making high way driving much nicer. 500-800 revs down in 5th gear would be nice, but then my area is most flat)
(Those of us using the jimny 98% time comuting and 2% offroading)
Your opinions
Your opinions
10 Mar 2021 19:01 #233626
by lightning
Replied by lightning on topic Jimny & Vitara Brezza
l guess it would be an improvement on flat roads, but the little N/A 1.5 Jimny motor might struggle on hills with such a high gear.
Ours is great at 65mph l am not sure l would want to cruise at much higher speeds than that in a Jimny.
The following user(s) said Thank You: lookonimages
11 Mar 2021 13:18 #233642
by fordem
Replied by fordem on topic Jimny & Vitara Brezza
Isn't the Vitara Brezza a transverse engine front wheel drive/all wheel drive vehicle? Typically those will have a transaxle rather than the separate transmission, transfer case & axle setup that the front engined, rear wheel drive Jimny has.
A transmission swap will not be a quick & easy task.
- lookonimages
11 Mar 2021 15:23 #233646
by lookonimages
Replied by lookonimages on topic Re:Jimny & Vitara Brezza
Most probable. Think i will go check this out. Have not thought about this.fordem wrote: Isn't the Vitara Brezza a transverse engine front wheel drive/all wheel drive vehicle? Typically those will have a transaxle rather than the separate transmission, transfer case & axle setup that the front engined, rear wheel drive Jimny has.
Time to create page: 0.091 seconds
